查看: 56|回复: 0
coolant problem need help
 楼主| 发表于 2019-1-24 20:14:22 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hello i was wondering if anybody would know whats wrong with my 2003 volvo. I have cummins isx 475hp engine and im having problems with coolant temperature. I notice that while im driving my coolant temperature gauge is jumping back and forth from 175 to 190. While idling the temperature sometimes goes up to 215. I also noticed that my coolant expansion tank is full with coolant and from time to time i need to add coolant to my coolant tank. I change the thermostat and coolant temperature sensor but still the same thing is happening. Thank you for the help","pics":"[]","canComment":true}
GMT+8, 2026-2-4 12:15 , Processed in 0.055573 second(s), 23 queries .
