查看: 205|回复: 7
 楼主| 发表于 2019-11-24 08:24:58 来自手机 | 显示全部楼层 |阅读模式
{"text":".","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-11-24 18:27:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"their not as that smart you still half to enunciate and tell wind to put the periods in they're otherwise its just a run on string of nonsense jibberish and reading it is like watch ing a cfi driver trying to back up ate times also you still have to go back and edit eye no this is being picky and critical but hay if you can sit and watch people back up ate times but not post about it till your on the road driving than anything's possible","replyToPid":0}
回复 支持 4 反对 1
发表于 2019-11-24 18:49:15 来自手机 | 显示全部楼层
815562 发表于 2019-11-24 00:29:38 I am driving and using voice to text it's not my fault that I have a smartphone that's not doing its job right
","text":"passing the blame, yet most of your posts are like this. So how about you try posting when you're parked.","replyToPid":260845}
发表于 2019-11-24 08:27:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"you seriously need to learn how to use periods and form complete sentences Elian Gonzalez","replyToPid":0}
 楼主| 发表于 2019-11-24 08:29:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"I am driving and using voice to text it's not my fault that I have a smartphone that's not doing its job right","replyToPid":0}
 楼主| 发表于 2019-11-24 20:37:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"not gona lie and dont even want to insult anyone but if you guys really cant read or use common sance to understand anything because theres no commas or periods then you guys are a bunch of idiots because even i can understand petrefied msg and its a mess as well","replyToPid":0}
发表于 2019-11-24 23:14:04 来自手机 | 显示全部楼层
815562 发表于 2019-11-24 12:37:51 not gona lie and dont even want to insult anyone but if you guys really cant read or use common sance to understand anything because theres no commas or periods then you guys are a bunch of idiots because even i can understand petrefied msg and its a mess as well
","text":"Hi! I'm Sarcasm and this is my friend, Irony. Pleased to meet ya, stranger!😀🤟✌️","replyToPid":261224}
发表于 2019-11-24 22:08:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"if you would keep your nose where it's supposed to be you probably wouldn't have anything to post....... so........","replyToPid":0}
GMT+8, 2026-4-19 15:29 , Processed in 0.092678 second(s), 24 queries .
