查看: 288|回复: 14
Volvo d13 2009 bad turbo
 楼主| 发表于 2019-11-23 12:06:10 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hi there, does anybody know where can I find used good working turbo, what could be the price, or is there somewhere I can repair it. Truck runs, boost gauge is moving but till 1/3 only. It’s bad on fuel and barely can take any hill decently. Any help is highly appreciated. ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-11-24 01:20:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"you very well could have an issue with the vgt as well. when it goes the turbo will get partial boost, truck will run but be sluggish. meeting cost me about $1400 on an isx15, it can be replaced without a shop, however it needs to be reprogrammed via engine specific diagnostics.","replyToPid":0}
发表于 2019-11-24 00:21:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"check your. air 2 air got a leak somewhere","replyToPid":0}
发表于 2019-11-23 21:52:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"I don't think you need turbo. You got another issue. when turbo goes bad. it typically blows apart. You will know it.  dumps oil  out exhaust.","replyToPid":0}
发表于 2019-11-23 14:32:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"Your location may be helpful for starters","replyToPid":0}
发表于 2019-11-24 00:38:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"Driver, when you are on a hill, pull over shut your truck off and turn it back on does it run well?","replyToPid":0}
发表于 2019-11-24 00:39:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"also one other question does your turbo not seem to work between certain RPMs particularly the lower range?","replyToPid":0}
发表于 2019-11-24 07:46:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"it's not a good idea to buy anything use for your truck just to save yourself a couple of $100","replyToPid":0}
 楼主| 发表于 2019-11-29 09:25:22 来自手机 | 显示全部楼层
612134 发表于 2019-11-23 06:32:23 Your location may be helpful for starters
","text":"I run mostly east coast, but we can use triangle ny il fl. Thanks","replyToPid":260315}
 楼主| 发表于 2019-11-29 09:28:36 来自手机 | 显示全部楼层
484866 发表于 2019-11-23 13:52:03 I don't think you need turbo. You got another issue. when turbo goes bad. it typically blows apart. You will know it.  dumps oil  out exhaust.
","text":"I had a mechanic to disconnect actuator, there’s switch (arm) which is not moving, mechanic told me that should be able to move if you try to move it with hand. I do have some kind of leak behind turbo, I’m able to hear hissing when I hit the gas pedal","replyToPid":260407}
GMT+8, 2026-4-18 12:46 , Processed in 0.101977 second(s), 24 queries .
