查看: 92|回复: 10
What features would you like to see in Hours of Service eLogs & ELD solution?
 楼主| 发表于 2019-11-23 06:12:42 来自手机 | 显示全部楼层 |阅读模式
发表于 2019-11-23 11:15:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"you talk bullishit. Guy above you is real driver and you are clown. I guess you are company driver with small d... and over 300 pounds","replyToPid":0}
发表于 2019-11-23 08:19:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"The government say we know nothing about what drivers do and tell us do it you’re way and be safe. 22 years driving and all my unsafe and tired driving speeding taking chances has been done from the ELD being installed till now ","replyToPid":0}
发表于 2019-11-23 09:36:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"No auto-switching to drive when at warehouses.","replyToPid":0}
发表于 2019-11-23 09:38:18 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"If you are a true professional, this doesn’t change anything for you, unlike the clown above me.  I start and end my day at roughly the same time each day for the past 16 years, these ELD and HOS changes have not affected that one bit.\n\nMost of the issue here is that drivers are too afraid to speak up.  If you don’t feel like you have enough time to get loaded or unloaded don’t do it, it’s that simple.  If you’re kept past your time, don’t move that truck, have it towed or you break right there."}
发表于 2019-11-23 11:13:55 来自手机 | 显示全部楼层
If you are a true professional, this doesn’t change anything for you, unlike the clown above me. I start and end my day at roughly the same time each day for the past 16 years, these ELD and HOS changes have not affected that one bit. Most of the issue here is that drivers are too afraid to speak up. If you don’t feel like you have enough time to get loaded or unloaded don’t do it, it’s that simple. If you’re kept past your time, don’t move that truck, have it towed or you break right there.
{"replyToPid":260166,"replyTo":"
649885 发表于 2019-11-23 01:38:18 If you are a true professional, this doesn’t change anything for you, unlike the clown above me.  I start and end my day at roughly the same time each day for the past 16 years, these ELD and HOS changes have not affected that one bit.\n\nMost of the issue here is that drivers are too afraid to speak up.  If you don’t feel like you have enough time to get loaded or unloaded don’t do it, it’s that simple.  If you’re kept past your time, don’t move that truck, have it towed or you break right there.
","text":"s"}
发表于 2019-11-24 01:56:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"I would like the manufacturer to install a self destruct button on the elog machine","replyToPid":0}
发表于 2019-11-24 11:45:00 来自手机 | 显示全部楼层
705502 发表于 2019-11-23 01:36:23 No auto-switching to drive when at warehouses.
","text":"Yard move?","replyToPid":260162}
发表于 2019-11-24 12:11:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"Just wanting to keep it off duty in order to conserve as much as I can on the 70s.","replyToPid":261025}
发表于 2019-11-24 13:04:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"I feel like for every year you have driving you should get and extra 5 hours on your 70","replyToPid":0}
GMT+8, 2026-2-15 03:03 , Processed in 0.259378 second(s), 24 queries .
