查看: 146|回复: 6
Do you guys use actual distance or straight line distance?
 楼主| 发表于 2019-11-22 11:13:13 来自手机 | 显示全部楼层 |阅读模式
{"text":"Which is often used in your trucking journey?🚚🚛🚚","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-11-22 20:48:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"Air miles often don’t come close enough to actual road miles to trip plan effectively. ","replyToPid":0}
发表于 2019-11-22 11:42:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"Depends if I'm measuring my Bacock or not.","replyToPid":0}
发表于 2019-11-22 19:48:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"You need to use actual ","replyToPid":0}
发表于 2019-12-5 00:35:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"where I work we use paper map distance that's where if it looks too in across the maps then we can definitely make it in one day","replyToPid":0}
发表于 2019-12-5 02:54:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you're a local driver, trying decide whether or not you're exempt from logging, you use air miles. For calculating fees for distance between 2 points, you can use Household Moving Guide, or another accepted mileage guide, PC Miler, Rand McNally, or other accepted routing software, or use actual hub miles. For logging the miles driven, you must use the actual hub miles.","replyToPid":0}
发表于 2019-12-5 13:19:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"When the Hover jets I had cutom made for my truck and trailer are fueled, I use straight line.\n\nBut given the price of jet fuel and rates being in the dumps, I've cut back on delivering freight on rooftops and have to hang with the regular group that uses city streets and actual distance. \n\nOH THE SHAME!!!","replyToPid":0}
GMT+8, 2026-2-15 14:05 , Processed in 0.054386 second(s), 24 queries .
