查看: 280|回复: 11
Time to be extra careful 58 east in Virginia.
 楼主| 发表于 2019-11-20 14:30:51 来自手机 | 显示全部楼层 |阅读模式
{"text":"I hate doing this in an automatic with 44 in the box.  ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1104.0,\"name\":\"\",\"url\":\"\",\"width\":828.0},{\"description\":\"\",\"height\":620.0,\"name\":\"\",\"url\":\"\",\"width\":828.0}]","canComment":true}
发表于 2019-11-21 03:05:50 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"You can still put an automatic in manual mode or use a combination of cruise and the engine brake to creep at any speed you like. You may have to put the engine brake on full blast and set cruise 10 or more mph slower than you actually want to go, but it’s super easy and safe once you figure it out. And you can bump the stalk to force it to downshift "}
发表于 2019-11-21 14:40:11 来自手机 | 显示全部楼层
497499 发表于 2019-11-20 19:05:50 You can still put an automatic in manual mode or use a combination of cruise and the engine brake to creep at any speed you like. You may have to put the engine brake on full blast and set cruise 10 or more mph slower than you actually want to go, but it’s super easy and safe once you figure it out. And you can bump the stalk to force it to downshift
","text":"Yes, still better than the 12% grades on PA 484.","replyToPid":258096}
发表于 2019-11-20 20:15:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"I feel your pain.","replyToPid":0}
发表于 2019-11-21 01:38:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"vs a non camera phone? 🤦‍♂️","replyToPid":0}
 楼主| 发表于 2019-11-21 13:21:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"I was not driving by the way.  When this pic was taken.   ","replyToPid":0}
发表于 2019-11-21 13:29:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"At least it’s a nice view 😁","replyToPid":0}
发表于 2019-11-21 14:46:51 来自手机 | 显示全部楼层
688533 发表于 2019-11-21 06:40:11 Yes, still better than the 12% grades on PA 484.
","text":"The northeast has got some crazy roads for sure. ","replyToPid":258633}
发表于 2019-11-25 23:56:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"I here you","replyToPid":0}
发表于 2020-1-26 22:48:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"you should try us 20 thru  Charlottesville  Va","replyToPid":0}
GMT+8, 2026-4-18 18:42 , Processed in 0.095092 second(s), 24 queries .
