查看: 209|回复: 8
Best line that your trainer told you
 楼主| 发表于 2019-11-19 20:52:16 来自手机 | 显示全部楼层 |阅读模式
{"text":"What is it?  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-11-19 23:34:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you can't see it, don't trust it. If it doesn't feel right, look right, or if you're not comfortable with it, don't do it. 25% of driving a truck in snow is skill. The other 75% is knowing when not to do it. And as someone else once said, \"You can go too slow as much as you want, you can only go too fast once.\"","replyToPid":0}
回复 支持 6 反对 0
发表于 2019-11-20 11:04:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"He thought his wife was faithful! 😂🤣😅","replyToPid":0}
发表于 2019-11-20 12:07:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"no trainer self came out here learn it on my own","replyToPid":0}
发表于 2019-11-20 11:17:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"never had a trainer","replyToPid":0}
发表于 2019-11-20 12:08:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"(Live on.)","replyToPid":0}
发表于 2019-11-21 02:12:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"You need to care less!","replyToPid":0}
发表于 2019-11-25 23:34:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"Someone has to be the adult ","replyToPid":0}
发表于 2019-11-25 23:54:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"always lie when dispatch asks are you going to deliver on time say yes every time","replyToPid":0}
GMT+8, 2026-4-17 13:14 , Processed in 0.090788 second(s), 24 queries .
