查看: 304|回复: 9
I recently asked for winter driving tips on a different platform. They told me to keep my Pizza boxes.
 楼主| 发表于 2019-11-19 20:49:25 来自手机 | 显示全部楼层 |阅读模式
{"text":"I really don't know why? Are they playing with me. Or is it legit helpful  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-11-19 23:39:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"As far as pizza boxes go I’ve seen some drivers park on top of them to keep from sticking to the ground but it’s stupid to me just keep salt/sand bucket throw some on the ground or just pull forward and back to pack snow. ","replyToPid":0}
发表于 2019-11-20 00:24:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"When its snowing, 5 degrees outside, windy, 3 feet snow piled up overnight...you're going to need somewhere to drop a deuce.","replyToPid":0}
发表于 2019-11-20 00:01:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"Use the cardboard as a windbreaker to retain heat inside the truck while driving. A shovel to dig out the snow around the tires. Salt, sand, or kitty litter for traction. Anti-gel to prevent frozen diesel. \n\nOtherwise, shut down & eat something warm while staying warm.","replyToPid":0}
发表于 2019-11-19 22:18:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"oh lord lissen only tips u need while driving in winnter is slow down give ur self. plenty of room incase u mess up or if theres a sudden accident up ahead u have tome to think about ur next move dont swerve the truck so much so u dont lose traction make sure ur tires are all good just stat calm and drive winnters unpredictable theres nothing anyone can tell you here that will help u just stay focous and ull be fine","replyToPid":0}
 楼主| 发表于 2019-11-26 01:01:44 来自手机 | 显示全部楼层
705502 发表于 2019-11-19 16:01:19 Use the cardboard as a windbreaker to retain heat inside the truck while driving. A shovel to dig out the snow around the tires. Salt, sand, or kitty litter for traction. Anti-gel to prevent frozen diesel. \n\nOtherwise, shut down & eat something warm while staying warm.
","text":"Thanks thanks","replyToPid":257176}
 楼主| 发表于 2019-11-26 01:01:32 来自手机 | 显示全部楼层
456441 发表于 2019-11-19 15:39:22 As far as pizza boxes go I’ve seen some drivers park on top of them to keep from sticking to the ground but it’s stupid to me just keep salt/sand bucket throw some on the ground or just pull forward and back to pack snow.
","text":"Gotcha. Thanks","replyToPid":257160}
 楼主| 发表于 2019-11-26 01:01:22 来自手机 | 显示全部楼层
815562 发表于 2019-11-19 14:18:31 oh lord lissen only tips u need while driving in winnter is slow down give ur self. plenty of room incase u mess up or if theres a sudden accident up ahead u have tome to think about ur next move dont swerve the truck so much so u dont lose traction make sure ur tires are all good just stat calm and drive winnters unpredictable theres nothing anyone can tell you here that will help u just stay focous and ull be fine
","text":"Got it.","replyToPid":257126}
 楼主| 发表于 2019-11-26 01:01:54 来自手机 | 显示全部楼层
682141 发表于 2019-11-19 16:24:15 When its snowing, 5 degrees outside, windy, 3 feet snow piled up overnight...you're going to need somewhere to drop a deuce.
","text":"👌👌","replyToPid":257192}
发表于 2020-2-6 21:58:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"Just following up. Are you surviving winter?","replyToPid":0}
GMT+8, 2026-4-17 01:08 , Processed in 0.080097 second(s), 24 queries .
