查看: 84|回复: 7
Why hate on Freightliners?
 楼主| 发表于 2019-11-19 20:47:45 来自手机 | 显示全部楼层 |阅读模式
{"text":"I don’t understand why Freightliners are frowned upon and hated by so many drivers.  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-11-20 10:47:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"I don’t either I had 17 of them but they got a bad rap back in 70s ","replyToPid":0}
发表于 2019-11-21 13:08:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"they have too many sensors turning off the motor as your driving down the road.","replyToPid":0}
发表于 2019-11-21 13:13:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"Smith transport had me in a freightliner the DEF exhaust flexpipe wasn't straight enough causing the sensor to shut the Detroit motor down only able to do 10 miles an hour or shut the motor off","replyToPid":0}
发表于 2019-12-8 06:00:03 来自手机 | 显示全部楼层
They are not a bad truck, just kenworth and Peterbilt are better
{"replyToPid":258588,"replyTo":"
794377 发表于 2019-11-21 04:45:31 They are not a bad truck, just kenworth and Peterbilt are better
","text":"every Kenworth I have ever driven has had wiring problems. and all the paccar motors have had issues too. I personally had a paccar powered t880 mixer that the crankshaft went out under the plant getting it's very first load. then the same thing happened to another guy at the plant same pos mx11."}
发表于 2019-12-8 06:31:26 来自手机 | 显示全部楼层
852662 发表于 2019-12-07 22:00:03 every Kenworth I have ever driven has had wiring problems. and all the paccar motors have had issues too. I personally had a paccar powered t880 mixer that the crankshaft went out under the plant getting it's very first load. then the same thing happened to another guy at the plant same pos mx11.
","text":"freightliner arent bad trucks and paccar today is very overrated","replyToPid":277012}
发表于 2019-12-8 06:39:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"the new paccars age like shît.. looked at some used t680s a while ago..all the plastic cabinets inside breaks after only a few years, water in most of the lights, steering wheels worn away","replyToPid":0}
发表于 2019-12-8 06:48:57 来自手机 | 显示全部楼层
871816 发表于 2019-12-07 22:39:51 the new paccars age like shît.. looked at some used t680s a while ago..all the plastic cabinets inside breaks after only a few years, water in most of the lights, steering wheels worn away
","text":"I'm in a 12 t660 now and hate it. no room to do crap in the sleeper and no cabinets..","replyToPid":277033}
GMT+8, 2026-2-15 16:30 , Processed in 0.067378 second(s), 24 queries .
