查看: 120|回复: 5
Trying to run recaps is such a pain in the ###
 楼主| 发表于 2019-1-24 19:55:56 来自手机 | 显示全部楼层 |阅读模式
{"text":"I generally run out my available hours every day and break my 70 within 5.5 to 6 days.Recently I have been on the road nearly 2 full months and needed to relax a bit, so I started trying to run recaps.I slowed down and only ran 10 hours a day off my clock.The Peoplegarbage machine in my truck has no handy field to tell me my recaps for the next two days.It has been so long since I recapped, I forgot that it doesn't reset after the 7th day.So here I sit, after a week of running slow and easy so I could recap.And, since I shut down at 1400 yesterday, I will end up taking a 34 anyway.How in the hell you OTR recappers run this slow, I will never understand.","pics":"[]","canComment":true}
发表于 2019-4-15 22:44:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"We don't run slow, we run smart. I run 65 mph and I try to only drive 9.5 hours a day. Get a tablet write down your daily hours so you can visual keep track of your recap. Pushing harder and driving faster does not always make you more money. ","replyToPid":0}
发表于 2019-5-7 01:35:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you run out of 70 hrs in 5.5 to 6 days, you are burning your clock up unnecessarily. Clock management and running efficiently is the key to running recaps.","replyToPid":0}
发表于 2019-4-15 23:04:11 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I'll never take a 34 away from home, that's too much time to spend any extra money being made by not going home."}
发表于 2019-4-15 23:03:38 来自手机 | 显示全部楼层
发表于 2019-5-7 10:40:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"I refuse to 34.\n\nOnlay stipulation is if U's gettin' low hours 2nite & 2morrow nite.","replyToPid":0}
GMT+8, 2026-3-21 18:57 , Processed in 0.080319 second(s), 24 queries .
