查看: 318|回复: 14
dot
 楼主| 发表于 2019-11-18 21:55:39 来自手机 | 显示全部楼层 |阅读模式
{"text":"what to do if you run out of hours between traffic? a good question","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-11-19 01:16:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"Obviously you didn’t plan trip very well. Traffic starts and ends the same time every single day. Accidents are another story though but most happen in the same corridors. The ones that happen outside that is just what it is. So instead of planning to drive 11 hours plan on 9 hours Incase you get stuck this way you have the hours to get where you need to without using pc ","replyToPid":0}
回复 支持 9 反对 1
发表于 2019-11-19 01:08:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"Personal conveyance ","replyToPid":0}
发表于 2019-11-19 14:02:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"last week they shut down all lanes of 75 S when Trump was flying into Atlanta. DOT on all ramps preventing access. Traffic was backed up 40 miles at complete standstill. How do you plan for that?","replyToPid":0}
发表于 2019-11-19 07:11:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"Well, if you get pulled over and your logs checked, or when your company finds out, if you try to blame it on traffic the only answer you'll hear is, \"You should have planned your trip better.\"  That being said though it doesn't always account for some possibilities such as major accidents that close roads when you have no option to reroute.  The only thing you can do is make sure to try to add a little bit of a time factor in gradually as you near your drive time limit. If you know you only have 2 hours left, and especially if you're heading into higher volume traffic areas, consider other options to stop for the night before your preferred destination. You can always leave a little earlier after your 10 hours off.  Look at your options well in advance as you plan your trip. It's better than a ticket andtor a call from the powers that be","replyToPid":0}
发表于 2019-11-19 03:33:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"Don’t park on side of the road either way to much of that very dangerous for everybody ","replyToPid":0}
发表于 2019-11-20 05:15:58 来自手机 | 显示全部楼层
505517 发表于 2019-11-19 06:02:01 last week they shut down all lanes of 75 S when Trump was flying into Atlanta. DOT on all ramps preventing access. Traffic was backed up 40 miles at complete standstill. How do you plan for that?
","text":"that's as rare as an accident closing all lanes of a highway between you and the very next exit.","replyToPid":256095}
发表于 2019-11-19 08:18:42 来自手机 | 显示全部楼层
发表于 2019-11-19 08:13:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"it's called trip planning","replyToPid":0}
发表于 2019-11-20 05:30:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"Hardly any excuse to run out of time in traffic unless you just mean the 8 and you forget to take a 30.\n\nEvery major city will have traffic during normal rush hour times and you should always anticipate traffic during the daytime during non-rush hour times on weekdays.  Apps like this one even show traffic and are useful for seeing non-rush hour delays such as those caused by construction and accidents.\n\nI personally wont go through any major city during non-rush hour times unless I have over an hour of time available, just in case.  During rush hour times, I wont go through unless I have a few hours available to drive.  I'll park early or just stop to wait a few hours until after rush hour passes and traffic calms down.","replyToPid":0}
GMT+8, 2026-4-18 11:48 , Processed in 0.108737 second(s), 24 queries .
