查看: 168|回复: 7
Why do drivers get so offended over small things and make it into a huge deal and fight at eachother?
 楼主| 发表于 2019-11-18 21:45:58 来自手机 | 显示全部楼层 |阅读模式
{"text":" What happened to brotherhood?  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-11-18 23:03:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"Minorities happened. Apparently there's no brotherhood with the brothers from the hood.","replyToPid":0}
回复 支持 8 反对 5
发表于 2019-11-19 01:21:36 来自手机 | 显示全部楼层
484866 发表于 2019-11-18 14:01:08 I been in a truck 38 yrs. I've seen alot of changes. some for good and some for bad. Use to drivers worked as team. Now drivers are have no respect for each other.
","text":"Even 38 years ago it was already getting bad. People think respect is earned but in fact it’s never earned. You respect everyone until disrespected. ","replyToPid":255495}
回复 支持 6 反对 0
发表于 2019-11-19 00:31:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"I'LL FIGHT YOU RIGHT NOW!!! 😂","replyToPid":0}
发表于 2019-11-18 22:26:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"brotherhood went out the window when companies started letting idiots drive","replyToPid":0}
发表于 2019-11-18 22:01:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"I been in a truck 38 yrs. I've seen alot of changes. some for good and some for bad. Use to drivers worked as team. Now drivers are have no respect for each other.","replyToPid":0}
发表于 2019-11-18 21:53:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"I saw an instance where a driver was told “If you’re not fueling, you can’t park in the fuel island.” He escalated the situation by trying to run over the attendant and the police were called. Really petty. ","replyToPid":0}
发表于 2019-11-19 17:07:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"Racism","replyToPid":0}
GMT+8, 2026-2-15 18:20 , Processed in 0.054025 second(s), 24 queries .
