查看: 100|回复: 2
Can you do a cash advacne at a pump? Card is frozen due to fraud
 楼主| 发表于 2019-11-18 21:34:48 来自手机 | 显示全部楼层 |阅读模式
{"text":"I know I can use my comdata card at the pump to do a cash advance, but how does that work exactly? Anyone done it before?  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-11-19 01:31:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"Bitcoin","replyToPid":0}
发表于 2019-11-19 03:11:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yeah when you put gas it will ask you if you want to take money out. Select yes, then the amount you want back. After you fuel up go inside and tell them that you had an advance and the pump number. You will sign for it and get a copy of the receipt. That easy my friend. Stay safe ","replyToPid":0}
GMT+8, 2026-4-19 12:15 , Processed in 0.072772 second(s), 24 queries .
