查看: 237|回复: 17
5mph ELD rule 🤦🏽‍♀️
 楼主| 发表于 2019-11-18 02:08:38 来自手机 | 显示全部楼层 |阅读模式
{"text":"it’s ridiculous, it should be at least 11mph so your drive doesn’t kick in automatically. 5mph feels too slow \n\n(technically its 4mph because it’ll kick in at the moment it reaches 5) 😒","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-11-18 02:39:27 来自手机 | 显示全部楼层
795583 发表于 2019-11-17 18:16:19 you can your  company to raise it. i do drop & hook driving around the yard looking for trl messed me up a few times i went 5mph to 15 mph it kicks in after 15mph
","text":"You are using AOBRD. The 5mph is actual law. Your company won’t be able to bump it up on ELD. You will have option to use yard move. Which doesn’t use your drive time but is on duty time. ","replyToPid":254344}
发表于 2019-11-18 02:16:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"you can your  company to raise it. i do drop & hook driving around the yard looking for trl messed me up a few times i went 5mph to 15 mph it kicks in after 15mph","replyToPid":0}
发表于 2019-11-18 02:44:45 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"On my old truck I couldn’t keep it under 5 mph..... \n"}
发表于 2019-11-18 02:31:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yep, once they switch you out of AOBRD mode, you're limited to about (4.something), mph. And come Dec. 16th of this year, (less than a month away), everybody's will be switched over to this. 😳👎😱🤨😕","replyToPid":0}
发表于 2019-11-18 05:30:09 来自手机 | 显示全部楼层
310244 发表于 2019-11-17 20:51:37 Another option available is “Yard Move” which puts a driver “on duty” but allows movement up to 25mph within a certain distance.
","text":"Your experience may differ from mine.","replyToPid":254477}
发表于 2019-11-18 05:25:26 来自手机 | 显示全部楼层
","text":"That’s based on what your company sets and what eld system. \n\nMy company doesn’t have a set speed or distance for yard move. We have to manually switch it off yard move. We have had drivers drivers hours because they forgot to take it off. I myself drove 30 miles on the interstate before I realized I left it on yard move. ","replyToPid":254477}
发表于 2019-11-18 05:06:42 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Ah man...  Thank you for writing this, for I Have YM as a duty status but didn’t know what it was for. "}
发表于 2019-11-18 04:51:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Another option available is “Yard Move” which puts a driver “on duty” but allows movement up to 25mph within a certain distance.","replyToPid":0}
发表于 2019-11-18 04:04:49 来自手机 | 显示全部楼层
658864 发表于 2019-11-17 18:44:45 On my old truck I couldn’t keep it under 5 mph..... \n
","text":"Yeah it's hard to maintain on newer trucks. I try to use speedometer on GPS for this, since it shows mph in whole numbers and tenths. I.E. 4.3, 4.7 etc.","replyToPid":254382}
发表于 2019-11-18 04:01:31 来自手机 | 显示全部楼层
542330 发表于 2019-11-17 18:39:27 You are using AOBRD. The 5mph is actual law. Your company won’t be able to bump it up on ELD. You will have option to use yard move. Which doesn’t use your drive time but is on duty time.
","text":"True!","replyToPid":254376}
发表于 2019-11-18 02:46:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"yes i am on AOBRD well in December it'll go back am aware of yard option","replyToPid":0}
发表于 2019-11-18 04:17:32 来自手机 | 显示全部楼层
96080 发表于 2019-11-17 20:04:49 Yeah it's hard to maintain on newer trucks. I try to use speedometer on GPS for this, since it shows mph in whole numbers and tenths. I.E. 4.3, 4.7 etc.
","text":"That’s me right there! 😂😂😂 I use the GPS so I can see my speed.... ","replyToPid":254455}
发表于 2019-11-18 04:33:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"Guess I better start crawling.","replyToPid":0}
GMT+8, 2026-2-16 12:35 , Processed in 0.062274 second(s), 24 queries .
