查看: 293|回复: 12
Which one makes more for a solo driver?
 楼主| 发表于 2019-11-17 22:28:20 来自手机 | 显示全部楼层 |阅读模式
{"text":"Dry Van? Reefer? or Flatbed?  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-11-18 02:50:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"Flatbed most work reefer more responsibility van is last as it’s the easiest. ","replyToPid":0}
发表于 2019-11-18 21:40:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"Doesn’t car hauling require having some prior experience? ","replyToPid":255347}
发表于 2019-11-18 14:23:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"Flatbed or step deck","replyToPid":0}
发表于 2019-11-18 20:49:02 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Flatbed pays the most, also has the most work involved.\nReefer generally pays more then dry van, but also has some work involved.  You do mostly live loads and unloads plus you have to monitor the reefer unit.  Keep it fueled and make sure nothing goes wrong with it that could risk the load.\nDry Van normally pays less then reefer and is the easiest.  Can either be a lot of drop and hook or live load/unload depending on the company.\n\nWhen it comes to reefer and dry van, the pay difference doesn't really matter.  Can get more miles doing drop and hook dry van for less pay, or less miles for more pay sitting at docks doing reefer.  In the end, the pay rate doesn't necessarily have anything to do with the amount you take home at the end of the week.\n\nBut one benefit to reefer is the free food.  If you do reefer it would be wise to get a chest freezer and cooking equipment for your truck if possible.  An 80lb case of ground beef or 140lb of chicken breasts can feed a solo driver for a while.  "}
发表于 2019-11-18 21:31:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"Flatbed takes the most skill load security is a bit more tricky follow your heart ❤️ not the money 💰 trail what do you enjoy I enjoy back road driving ","replyToPid":0}
发表于 2019-11-18 15:01:43 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"why didnt you ask about tanker as well?\nI know of some tanker companies that start in the mid sixty cpm range.\nDepending on years of experience of course."}
发表于 2019-11-18 22:53:50 来自手机 | 显示全部楼层
658864 发表于 2019-11-18 13:40:19 Doesn’t car hauling require having some prior experience?
","text":"no call United Road Service they'll train you and pay you a salary your first year I think it's around 75 or 80k them you'll be at 25 percent","replyToPid":255440}
发表于 2019-11-18 14:33:50 来自手机 | 显示全部楼层
542330 发表于 2019-11-17 18:50:29 Flatbed most work reefer more responsibility van is last as it’s the easiest.
","text":"Exactly, correct 👍","replyToPid":254393}
发表于 2019-11-18 19:58:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"car hauling","replyToPid":0}
GMT+8, 2026-4-18 12:29 , Processed in 0.084093 second(s), 24 queries .
