查看: 371|回复: 20
What are the laws regarding alcohol as a CDL driver?
 楼主| 发表于 2019-11-16 21:49:05 来自手机 | 显示全部楼层 |阅读模式
{"text":"Basically, am I going to be able to have a glass of whiskey before falling asleep on my 10 HR break, and can I drink over my 34 hour resets OTR?  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-11-17 10:31:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"Depends on your company policy. However, 8 hours between bottle & throttle.","replyToPid":0}
发表于 2019-11-17 15:37:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"DOT can search the interior of any CMV with or without cause or warrant at anytime. The driver has no right to refuse. This includes on private property. They can and will search at truckstops. That said, they aren't generally out to mess with you, but I don't chance it. By the by, you are also responsible if a rider brings something illegal on. We are always the first to catch the blame and last to be cleared.","replyToPid":0}
发表于 2019-11-17 12:45:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"FMCSA makes it very clear but it's your call. All I would add is how important is your CDL to you and your livelihood.\nI love a couple of ice cold beers after mowing the yard or other physical chores around the house, but no one can say anything about it. \nIs it right? No, but it is what it is until drivers can get together and stick together.  As it is, it's probably going to be a driver you may know that drops that dime to get their nose a little more browned.","replyToPid":0}
发表于 2019-11-17 12:11:19 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"You cannot have any alcohol in a CMV whatsoever unless it’s sealed, packaged, and part of your load that won’t fit in the trailer and the BOL reflects that. If DOT does a surprise inspection and sees any evidence of you drinking in your truck even on a 34 hr restart you can lose your CDL. Call an Uber, Lyft, or cab and go to a bar. I haven’t checked in a while, but it used to be a minimum of 4 hrs from having a drink to operating a CMV. Check the books. "}
发表于 2019-11-17 10:33:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"I heard that you can’t even have it in the truck at all, I don’t drink much but I’ve put down a few in the truck. Just buy what you can handle then you won’t have to worry about keeping it in the truck. Just be careful whatever you do, the family probably prefers you come home in 1 piece. ","replyToPid":0}
发表于 2019-11-17 12:08:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"its illegal to have any open alcohol in an automotive of any size. or use. but check with the company policy and local laws where you're parked.","replyToPid":0}
发表于 2019-11-17 11:21:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"I've been told no alcohol whatsoever in the truck. Most companies have a zero tolerance even if your not drinking it...fired. I have had a few in the truck before. Usually at a terminal. I hid them, drank them, pissed in a gallon jug so i didnt have to see anyone and didnt have to get out of the truck. It's your call but for sure only buy what your gonna drink. If your going to drink I'd do it on a 34 for sure that's the only time I have but hey it's your call. Stay safe.","replyToPid":0}
发表于 2019-11-17 10:33:45 来自手机 | 显示全部楼层
{"replyTo":"","text":".04 is the limit for a CDL holder vs .08 for everyone else ","replyToPid":0}
发表于 2019-11-17 10:53:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"If Gen Chaos is buying the drinks RUN!","replyToPid":0}
发表于 2019-11-17 14:55:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"i used to have 2 bottles of brandy in every truck that i drive, and have 2 -3 shots before sleeping if it was below 15 degrees out there; but the way its been lately between me and cops; i stopped about year and a half ago! i wouldnt store a bottle no more; but yes; 2-4 shots of brandy ill be normal after a ten hour break","replyToPid":0}
GMT+8, 2026-4-17 14:51 , Processed in 0.110308 second(s), 25 queries .
