查看: 65|回复: 6
Prime Inc
 楼主| 发表于 2019-11-15 04:20:21 来自手机 | 显示全部楼层 |阅读模式
{"text":"What are all your trucks governed at? Seriously just curious? And how does it effect your deliver time and window?","videos":"[]","link":"{}","pics":"[]","canComment":true}
 楼主| 发表于 2019-12-20 11:14:00 来自手机 | 显示全部楼层
707995 发表于 2019-12-05 14:01:59 I trip plan at 55. I usually roll at 62 mph for optimal fuel mileage. If it’s a little tight I’ll roll at 65. I see Mercer owner ops cruising slower than me all the time. It’s all relative
","text":"Sorry for the late response, but thanks for the info. I was just curious as to how it is for dispatch and travel. Thanks Danielle!!","replyToPid":275175}
发表于 2019-12-5 22:01:59 来自手机 | 显示全部楼层
574721 发表于 2019-12-05 07:45:53 Well good to know I was just curious. What do you average your mph too then. Like 40-45 miles per hour? Meaning like you only go 40-45 miles in an hour. I usually base mine on 50-55, even though I am governed at 68.
","text":"I trip plan at 55. I usually roll at 62 mph for optimal fuel mileage. If it’s a little tight I’ll roll at 65. I see Mercer owner ops cruising slower than me all the time. It’s all relative ","replyToPid":275062}
发表于 2019-12-5 22:00:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"They’re* and no, they roll above min speed. The blinker is on the left.... use it to pass if necessary 🙄","replyToPid":0}
发表于 2019-12-5 19:08:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have no governor they need to speed those trucks up there a safety hazard ","replyToPid":0}
发表于 2019-12-4 11:30:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"65mph for lease ops. 57 on the pedal and I think 62-63 on cruise for Company drivers. It really doesn’t. They’re very understanding about load times, traffic, and miles. ","replyToPid":0}
 楼主| 发表于 2019-12-5 15:45:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"Well good to know I was just curious. What do you average your mph too then. Like 40-45 miles per hour? Meaning like you only go 40-45 miles in an hour. I usually base mine on 50-55, even though I am governed at 68. ","replyToPid":0}
GMT+8, 2026-2-17 02:56 , Processed in 0.091003 second(s), 24 queries .
