查看: 299|回复: 10
driver's enjoy you're high pressure water at next shower!! 🤣🤣
 楼主| 发表于 2019-11-14 07:19:29 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[]","link":"{}","pics":"[{\"description\":\"🚿🚿🚿🚿🚿🛁🛁🛁🛁🛁\",\"height\":2000.0,\"name\":\"\",\"url\":\"\",\"width\":1500.0}]","canComment":true}
发表于 2019-11-14 09:24:12 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Removing the flow restrictor , and thank you. It's not like the truck stops don't try to gouge us enough already,  right!"}
回复 支持 2 反对 2
 楼主| 发表于 2019-11-14 10:33:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"I'm here to make driver's life ez","replyToPid":250756}
发表于 2019-11-14 07:24:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"What’s that you’re doing? ","replyToPid":0}
 楼主| 发表于 2019-11-14 10:14:37 来自手机 | 显示全部楼层
662224 发表于 2019-11-14 01:24:12 Removing the flow restrictor , and thank you. It's not like the truck stops don't try to gouge us enough already,  right!
","text":"of course You're right\nthanks for the support","replyToPid":250720}
 楼主| 发表于 2019-11-14 08:18:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"you're welcome","replyToPid":0}
发表于 2019-11-14 09:25:07 来自手机 | 显示全部楼层
","text":"Replying to Mango.","replyToPid":250720}
发表于 2019-11-15 08:11:58 来自手机 | 显示全部楼层
855521 发表于 2019-11-15 00:04:09 That's from retàrded drivers dismantling shower heads because they think they are accomplishing something when the water pressure is generated before the shower head.
","text":"Yep, that was the point I was facetiously trying to make. If you're gonna screw with it, don't mess it up for everyone else. 👍","replyToPid":251342}
发表于 2019-11-14 09:38:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’m always happy to get a shower with high water pressure! Sometimes I don’t feel clean after a shower....","replyToPid":0}
发表于 2019-11-14 10:24:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"🤣🤣🤣","replyToPid":0}
发表于 2019-11-15 07:37:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"Sweet. I should carry a extra shower head too! But what kills me at the truck stops is when the teflon  tape is put on backwards and is falling out and leaks everywhere but onto you. lol","replyToPid":0}
GMT+8, 2026-2-14 11:51 , Processed in 0.073322 second(s), 24 queries .
