查看: 112|回复: 13
They say they don't have time
 楼主| 发表于 2019-11-13 21:43:09 来自手机 | 显示全部楼层 |阅读模式
{"text":"The reality is I am seeing people take showers, take their 30 at the pump.  ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":748.0,\"name\":\"222/Test%25205_1573652585_1573652586.jpg\",\"url\":\"\",\"width\":960.0}]","canComment":true}
发表于 2019-11-14 01:34:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"if they do the stuff that takes the longest it's faster.   For instance, go to Carl's jr first and order then go to the bathroom go back to Carl's jr to pick up the food  it will take less time . I have got fuel and Carl's jr  less then 20 min. But I don't order food if the line is to long and I always pull up so someone can get fuel.","replyToPid":0}
发表于 2019-11-14 08:49:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"Apes","replyToPid":0}
发表于 2019-11-14 04:11:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"Truck stops need to start placing signage at the pumps saying something along the lines of “Fuel Up ‘N’ Pull Up.” No parking at pumps. No showers or DOT breaks at pumps. ","replyToPid":0}
发表于 2019-11-14 00:18:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yep, it's just Stupid!","replyToPid":0}
发表于 2019-11-14 07:08:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"yea you all forgot the biggest problem guys put garbage pail in lane to block pump and go to !!!!! sleep I have no good words to write for what they really are!!!!!","replyToPid":0}
发表于 2019-11-14 21:56:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’d shît on their door step. \n\nNot a bag of shît. \n\nPants down an really lean into it. ","replyToPid":0}
 楼主| 发表于 2019-11-16 18:56:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"true","replyToPid":250340}
 楼主| 发表于 2019-11-16 18:56:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"huh? not me","replyToPid":250397}
 楼主| 发表于 2019-11-16 18:56:58 来自手机 | 显示全部楼层
740223 发表于 2019-11-13 17:34:32 if they do the stuff that takes the longest it's faster.   For instance, go to Carl's jr first and order then go to the bathroom go back to Carl's jr to pick up the food  it will take less time . I have got fuel and Carl's jr  less then 20 min. But I don't order food if the line is to long and I always pull up so someone can get fuel.
","text":"🤔","replyToPid":250401}
GMT+8, 2026-2-13 18:16 , Processed in 0.072349 second(s), 24 queries .
