查看: 419|回复: 24
I’m confused how to read this how many miles did I get i started driving Thursday and didn’t stop till Friday
 楼主| 发表于 2019-5-24 21:18:02 来自手机 | 显示全部楼层 |阅读模式
{"text":"I’m confused can someone explain it to me how many miles did I get in total my last 14 hrs clock for Thursday and Friday ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":480.0,\"name\":\"\",\"url\":\"\",\"width\":640.0}]","canComment":true}
发表于 2019-5-24 22:28:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"You drove 658 in your shift.  Because of the way it was split up it looks like you drove more. But it was 2 separate shifts","replyToPid":0}
发表于 2019-5-25 02:43:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"Each driver has to log a pre or post trip. You will get nailed if dot looks at your logs because when you start driving you take responsibility for the truck trailer and load. ","replyToPid":0}
发表于 2019-5-24 23:54:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"Looks like about 650 miles in your last 14. Now should we count number of log violations we can see in 2 days. At lest 1 no pre/post trip and falsifying logs as in 1000+ miles no fuel ","replyToPid":0}
发表于 2019-5-24 22:23:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"You can multiply the amount of hours you drove by your average speed to get a rough estimate","replyToPid":0}
发表于 2019-5-31 13:41:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"you must log a pre trip, and I believe also a post.  Your trainer is wrong if he is saying you don't need to.  Check your DoT manual.  Trainers have been known to be wrong and you are the one on the hook for violations on your log.","replyToPid":0}
发表于 2019-5-26 06:47:20 来自手机 | 显示全部楼层
639250 发表于 2019-05-24 18:56:13 Well he is saying I don’t need too so ima do it his way for two more weeks
","text":"So your trainer is using you as a steering wheel holder🤔🤔 some things never change. ","replyToPid":43334}
 楼主| 发表于 2019-5-25 02:56:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"Well he is saying I don’t need too so ima do it his way for two more weeks","replyToPid":0}
发表于 2019-5-24 21:19:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"That’s easy 658 plus 451 ","replyToPid":0}
 楼主| 发表于 2019-5-24 21:21:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"So I drove of 1k miles in a 14 hour shift?","replyToPid":0}
发表于 2019-5-24 22:21:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’m not familiar with that elog, but is there a different tab you can use to see your miles?","replyToPid":0}
发表于 2019-5-25 00:57:37 来自手机 | 显示全部楼层
645234 发表于 2019-05-24 13:19:39 That’s easy 658 plus 451
","text":"No. That’s driving miles for 17+ hours. Those are two 24 hour days. This is all miles not just a particular 14 day. ","replyToPid":42989}
发表于 2019-5-25 01:00:42 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"You’re running a Zonar. It’s only telling you what you ran from midnight to midnight. That’s the downside of running through the night because it breaks up the miles driven on one shift into two different totals. You can retest a tripometer to track particular trips or shifts if you want. "}
发表于 2019-5-25 01:03:46 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"."}
GMT+8, 2026-4-17 05:11 , Processed in 0.174693 second(s), 24 queries .
