查看: 4063|回复: 17
10 Safety Tips for Hitting the Road this Winter
 楼主| 发表于 2019-11-13 13:37:06 来自手机 | 显示全部楼层 |阅读模式
{"text":"Navigating the road during winter can be difficult even for expert truckers. During this season, truckers have to put up with icy roads, poor visibility, and reduced traction while driving a big rig. However, implementing preventive safety precautions can help you sail smoothly throughout winter without any major problems.\n\n1) Vehicle Inspection\n\nBefore anything else, you need to ensure that your truck is in the best shape to survive the tough conditions of the winter season. See your tire pressure, antifreeze levels, and engine oil before your trip. If you have the time and the means, have a mechanic inspect your vehicle. This will help ensure that your vehicle can withstand the harsh conditions during winter.\n\n2) Watch Your Speed\n\nAccidents during the winter season mostly happen due to overspeeding. Driving through an icy road can result in poor traction. This is why it’s wise to compensate by reducing your speed. Going easy on your accelerator also gives you a longer reaction time should things go south. \n\n3) Allow Extra Space\n\nWhile driving on wet roads, stopping distance is usually twice more than normal. However, stopping distance increases to 10 times more than usual on icy roads. This is why you have to leave lots of room between your truck and the vehicle in front of you. Doing this will keep you out of harm’s way during accidents.\n\n4) Be Smooth\n\nDon’t do any sudden movements on icy roads. Refrain from sudden brakes, acceleration, etc. Should you find yourself in a sticky situation, lightly pump your brakes. Be sure to keep your speed consistent. Avoid doing anything that will reduce your traction on a slippery, icy road.\n\n5) Pay Attention to Tire Spray\n\nOne quick way to assess the road’s condition is to observe the water coming off the tires of surrounding vehicles. More water indicates wetter roads. Meanwhile, less tire spray indicates icy roads. This should prompt you to exercise more caution while driving. \n\n6) Light the Way\n\nVisibility can decrease relatively due to poor weather conditions. Don’t forget to turn your headlights on while driving. This allows other drivers to keep a safe distance from your truck. \n\n7) Be Evasive\n\nBe evasive on snow-covered roads. This is relatively better instead of sudden and hard braking. Decelerate your truck slightly and carefully maneuver through obstacles to avoid collisions. \n\n8) Avoid Extreme Conditions\n\nIf the weather seems too severe, pull over. There’s no point in risking a drive during extreme weather conditions. Your safety should always come first. If the weather gets too extreme, find a safe way to get off the road and wait until it’s safe enough to drive. \n\n9) Prepare Yourself\n\nAfter you’ve ensured that your vehicle is ready for winter, it’s time to prep for the cold weather. Be sure to carry warm clothes and thick blankets. It won’t hurt to bring miscellaneous items like a flashlight, shovel, matches, traction devices, etc. You would never know when these things may come in handy. It’s also to make sure you have roadside assistance for trucks should you encounter trouble on the road.\n\n10) Double-Check\n\nDuring a whiteout blizzard, visibility is compromised. This will make it difficult to see traffic lights and road signs. Stay safe by looking twice before proceeding on intersections or one-way streets. \n\nTruckers are constantly being tested on the road. As winter begins, it brings with it obstacles that make driving challenging. During this season, it’s important to exercise caution while driving. These tips can help prevent accidents and mishaps from happening during the drive.","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":319.0,\"name\":\"\",\"url\":\"\",\"width\":613.0}]","canComment":true}
发表于 2019-11-21 13:37:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"12) Avoid Swift trucks by 1,000 feet if passing is necessary, pray.","replyToPid":0}
回复 支持 9 反对 0
发表于 2019-11-21 10:10:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thanks for those great tips! It will be my first winter!","replyToPid":0}
回复 支持 4 反对 1
发表于 2019-11-26 09:16:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you have big payment  on your truck  that  you  don't need  worry abaut  weather  just  open  eyes  and  be safe on road","replyToPid":0}
发表于 2019-11-21 13:36:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"11)Take a dump in your truck","replyToPid":0}
发表于 2019-11-26 09:52:10 来自手机 | 显示全部楼层
684281 发表于 2019-11-21 02:10:59 Thanks for those great tips! It will be my first winter!
","text":"My first winter with a big rig . I will arm myself with these good tips . Thank you .","replyToPid":258439}
发表于 2019-11-26 09:26:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"thank u","replyToPid":0}
发表于 2019-11-26 11:03:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thanks for the Tips, Always safety better than Sorry","replyToPid":0}
发表于 2019-11-26 10:28:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"that's great instructions 👍","replyToPid":0}
发表于 2019-11-26 10:26:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"thank you for reminding ","replyToPid":0}
发表于 2019-11-26 09:25:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"thanks guys","replyToPid":0}
发表于 2019-11-21 13:01:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"Restrict ","replyToPid":0}
发表于 2019-11-23 11:21:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"Great tips! Thank you for sharing","replyToPid":0}
发表于 2019-11-26 09:23:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"gr8 tips,b safe all my fellows","replyToPid":0}
发表于 2019-11-26 09:23:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"Great times thanks ","replyToPid":0}
GMT+8, 2026-4-16 12:06 , Processed in 0.184841 second(s), 25 queries .
