查看: 236|回复: 8
Of course this S&&& has to happen on the middle no where :( 🤦🏽‍♂️🙏🏽🙏🏽
 楼主| 发表于 2019-11-13 10:19:23 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1472.0,\"name\":\"\",\"url\":\"\",\"width\":828.0}]","canComment":true}
发表于 2019-11-13 14:16:12 来自手机 | 显示全部楼层
731716 发表于 2019-11-13 04:29:09 Most likely DEF, oil or coolant issue. Each time I’ve gotten the red stop engine it’s been a faulty sensor. Should be an easy fix if you can someone out there
","text":"🤣 Translation: It's going to be something...","replyToPid":249932}
发表于 2019-11-13 12:13:33 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Eat a bullet"}
发表于 2019-11-13 12:29:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"Most likely DEF, oil or coolant issue. Each time I’ve gotten the red stop engine it’s been a faulty sensor. Should be an easy fix if you can someone out there","replyToPid":0}
发表于 2019-11-13 12:12:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"Be careful and stay warm ","replyToPid":0}
 楼主| 发表于 2019-11-13 12:59:48 来自手机 | 显示全部楼层
","text":"🤙🏽 oil level are good and coolant . Ty brother. ","replyToPid":249932}
发表于 2019-11-13 16:45:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"Overheating? ","replyToPid":0}
发表于 2019-11-15 17:10:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"Most likely a loose connection in the battery box... it’s happened to me.","replyToPid":0}
发表于 2019-11-15 17:11:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"Still a racist in 2019 😆 loser","replyToPid":249921}
GMT+8, 2026-4-19 10:09 , Processed in 0.086621 second(s), 25 queries .
