查看: 285|回复: 13
How hard is it to drive a semi during winter season?
 楼主| 发表于 2019-11-12 20:53:36 来自手机 | 显示全部楼层 |阅读模式
{"text":"If you were to give it a score from 1-10 with 10 as the highest. How are you doing to rate it?  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-11-13 00:27:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"When I was new 7 now 0 or 1 cause if it’s to bad I don’t drive ","replyToPid":0}
发表于 2019-11-13 02:14:03 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"First few years were a little scary for me. I’d rate them about an 8. Now it’s just common sense. If you see road spray coming off of another vehicle’s tires, it’s not ice. Still, slow down a little, because the slushee stuff can be dangerous as well. A lot of states are getting a little better at clearing roads before they get too bad. Indiana, however, is NOT one of them. And if it’s really bad out, Park it!! They’ll still need that load when you get it there."}
 楼主| 发表于 2019-11-13 17:47:11 来自手机 | 显示全部楼层
456441 发表于 2019-11-12 16:27:48 When I was new 7 now 0 or 1 cause if it’s to bad I don’t drive
","text":"Thanks for the tip","replyToPid":249414}
发表于 2019-11-13 10:30:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you have to ask you're going to die","replyToPid":0}
发表于 2019-11-13 02:16:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"unless the road is closed it's always fine to drive. just slow down.","replyToPid":0}
发表于 2019-11-13 03:34:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"It's all on the driver to judge their skills w/ the weather conditions or when the state shuts ya down.","replyToPid":0}
发表于 2019-11-13 10:27:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"-9","replyToPid":0}
 楼主| 发表于 2019-11-13 17:47:20 来自手机 | 显示全部楼层
327523 发表于 2019-11-12 18:14:03 First few years were a little scary for me. I’d rate them about an 8. Now it’s just common sense. If you see road spray coming off of another vehicle’s tires, it’s not ice. Still, slow down a little, because the slushee stuff can be dangerous as well. A lot of states are getting a little better at clearing roads before they get too bad. Indiana, however, is NOT one of them. And if it’s really bad out, Park it!! They’ll still need that load when you get it there.
","text":"Got it. ty","replyToPid":249484}
 楼主| 发表于 2019-11-13 17:47:27 来自手机 | 显示全部楼层
682141 发表于 2019-11-12 18:16:59 unless the road is closed it's always fine to drive. just slow down.
","text":"how low?","replyToPid":249486}
GMT+8, 2026-4-17 18:05 , Processed in 0.190419 second(s), 24 queries .
