查看: 309|回复: 13
first winter
 楼主| 发表于 2019-11-12 11:42:01 来自手机 | 显示全部楼层 |阅读模式
{"text":"this it's going to be my first winter driving a heavy truck guys any advise for safety  will be appreciated..y'all be safe out there ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-11-12 19:51:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"Keep in mind, everything in your trailer is already dead or was never living--thus, rushing isn't worth your life. Slow it down, let the speedy Gonzales' pass--you might see 'em again, with wheels up or laying over.\n\nThe  food advice is golden. Also keep some heavy duty plastic bags and clorox/bleach in case you get stuck for several hours to a couple days-- a restroom might not be available. I think you know where I'm going with this.\n\nStay safe Driver.","replyToPid":0}
回复 支持 4 反对 1
发表于 2019-11-12 12:03:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"Drive whatever speed you are comfortable with. \n\nHave water/drinks and food at all times in your truck. Several days worth. You never know if you get some place in the middle of no where. \n\nHave warm clothes and bedding. \n\nRubbing alcohol in wiper fluid. To stop the fluid from freezing and melts ice on windshield. 1/2 a bottle the little ones to 1 gallon of wiper fluid. ","replyToPid":0}
回复 支持 4 反对 1
发表于 2019-11-13 03:24:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"chains are to get you out of trouble. not into trouble. use them only if you have to remember you have the right to do a weather shut down if you don't feel safe to drive that truck","replyToPid":0}
发表于 2019-11-13 03:24:30 来自手机 | 显示全部楼层
852875 发表于 2019-11-12 15:02:52 thanks for the help I really appreciate it 👍
","text":"You posted the same thing that I was gonna post but you beat me to it. Thx for all the advice ","replyToPid":249383}
发表于 2019-11-12 16:46:47 来自手机 | 显示全部楼层
542330 发表于 2019-11-12 04:03:57 Drive whatever speed you are comfortable with. \n\nHave water/drinks and food at all times in your truck. Several days worth. You never know if you get some place in the middle of no where. \n\nHave warm clothes and bedding. \n\nRubbing alcohol in wiper fluid. To stop the fluid from freezing and melts ice on windshield. 1/2 a bottle the little ones to 1 gallon of wiper fluid.
","text":"I also use vinegar if I don't have rubbing alcohol it works wonders to","replyToPid":248819}
发表于 2019-11-17 14:48:17 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Take it slow, if you feel you can't handle the weather find a safe haven and park your life is not worth the load. Always have food water and whatever beverages you're into at least 4-5 days worth depending on how bad it gets in the highways. If you got the money, invest in some wool base layers wool socks. Get a good jacket to handle the weather like a 3-n-1, some waterproof gloves. Rubbing alcohol for the airlines. Idle, never set your trailer brakes. Lastly and perhaps the most important one anti-gel. at least 2 bottles worth."}
发表于 2019-11-12 17:34:37 来自手机 | 显示全部楼层
 楼主| 发表于 2019-11-18 01:16:00 来自手机 | 显示全部楼层
629466 发表于 2019-11-17 06:48:17 Take it slow, if you feel you can't handle the weather find a safe haven and park your life is not worth the load. Always have food water and whatever beverages you're into at least 4-5 days worth depending on how bad it gets in the highways. If you got the money, invest in some wool base layers wool socks. Get a good jacket to handle the weather like a 3-n-1, some waterproof gloves. Rubbing alcohol for the airlines. Idle, never set your trailer brakes. Lastly and perhaps the most important one anti-gel. at least 2 bottles worth.
","text":"thanks for the advices Jwee👍","replyToPid":253901}
发表于 2019-11-14 04:30:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"slow down and just chill","replyToPid":0}
 楼主| 发表于 2019-11-13 04:30:24 来自手机 | 显示全部楼层
","text":"thanks for the tips 👍","replyToPid":248819}
 楼主| 发表于 2019-11-12 23:00:15 来自手机 | 显示全部楼层
 楼主| 发表于 2019-11-12 23:02:52 来自手机 | 显示全部楼层
854702 发表于 2019-11-12 11:51:01 Keep in mind, everything in your trailer is already dead or was never living--thus, rushing isn't worth your life. Slow it down, let the speedy Gonzales' pass--you might see 'em again, with wheels up or laying over.\n\nThe  food advice is golden. Also keep some heavy duty plastic bags and clorox/bleach in case you get stuck for several hours to a couple days-- a restroom might not be available. I think you know where I'm going with this.\n\nStay safe Driver.
","text":"thanks for the help I really appreciate it 👍","replyToPid":249168}
 楼主| 发表于 2019-11-13 04:29:26 来自手机 | 显示全部楼层
","text":"thanks you 👍","replyToPid":249168}
GMT+8, 2026-4-19 10:04 , Processed in 0.124165 second(s), 25 queries .
