查看: 159|回复: 10
Winter Tips
 楼主| 发表于 2019-11-12 10:04:54 来自手机 | 显示全部楼层 |阅读模式
{"text":"I'm curious what tips and tricks you guys have for winter time and driving. \n\n- keep some ice melt and kitty litter on truck\n- always keep fuel above half tank \n- keep food and water on truck\n- a sleeping bag 30° and below \n- extra gloves/jacket\n- diesel 911\n- rubbing alcohol \n\n\nThese are some of the things I know of in case you get stranded somewhere......can you add to it? ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-11-12 11:16:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"Just little advice \nNewer dump air from trailer when sleeping over night in freezing temperatures ","replyToPid":0}
发表于 2019-11-12 13:58:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Helps prevent condensation in the lines freezing your brakes.","replyToPid":248866}
发表于 2019-11-12 14:06:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"Layers are better than one big jacket.","replyToPid":0}
 楼主| 发表于 2019-11-12 13:07:20 来自手机 | 显示全部楼层
664676 发表于 2019-11-12 03:16:19 Just little advice \nNewer dump air from trailer when sleeping over night in freezing temperatures
","text":"Care to elaborate why?","replyToPid":248792}
 楼主| 发表于 2019-11-12 14:20:33 来自手机 | 显示全部楼层
851250 发表于 2019-11-12 05:58:37 Helps prevent condensation in the lines freezing your brakes.
","text":"thank you","replyToPid":248914}
发表于 2019-11-12 18:30:00 来自手机 | 显示全部楼层
","text":"Nooooo\nJust brake pads get freeze to drums and will get stock in the morning. Nothing to do with condensation ","replyToPid":248914}
发表于 2019-11-12 18:32:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"Brake shoes sorry ","replyToPid":0}
发表于 2019-11-12 21:24:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"When you park at night and it’s snow back don’t put your trailer brakes on they will freeze you should wait 20 minutes or so and move alittle so your tires won’t melt down in ice you will be stuck and if brakes freeze try to back up they might release ","replyToPid":0}
发表于 2019-11-13 01:30:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"Never take advice from someone that tells you not to set your brakes. The reason trailer brakes freeze is because no one, including myself because not cold enough on my route yet, drains the trailer air tanks. If you've never done it you could probably collect half a cup of rusty condensation from the tanks. Same goes for truck tanks.","replyToPid":0}
GMT+8, 2026-2-14 09:06 , Processed in 0.062747 second(s), 24 queries .
