查看: 127|回复: 8
Got a cobra 29 LX. most saying lately I sound like I'm breaking up. I tried everything. any advice??
 楼主| 发表于 2019-5-24 13:35:18 来自手机 | 显示全部楼层 |阅读模式
发表于 2019-5-26 01:35:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"if it is hanging and swings alot it will destroy the wires at the plug a lot of the times. borrow somebody's mic and see if it clears it up or buy one, never hurts to have a spare one on hand.","replyToPid":0}
 楼主| 发表于 2019-5-26 01:20:50 来自手机 | 显示全部楼层
160853 发表于 2019-05-24 11:18:55 Check all wire connections, coax connections should never be crimped on but soldered, and check for kinks are n the coax cable itself and  hopefully you don’t have too long of cable and have the excess wrapped up neatly together, this creates a “choke.” Are your antennas grounded to the vehicle well?
","text":"yeah. my power supply at moment is dc outlet.","replyToPid":42943}
发表于 2019-5-26 04:09:30 来自手机 | 显示全部楼层
610123 发表于 2019-05-25 17:35:04 if it is hanging and swings alot it will destroy the wires at the plug a lot of the times. borrow somebody's mic and see if it clears it up or buy one, never hurts to have a spare one on hand.
","text":"yep i had 2 different mics go bad from this same thing","replyToPid":44106}
发表于 2019-5-24 19:01:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"How old is your microphone, sometimes it's as simple as that.","replyToPid":0}
发表于 2019-5-24 19:18:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"Check all wire connections, coax connections should never be crimped on but soldered, and check for kinks are n the coax cable itself and  hopefully you don’t have too long of cable and have the excess wrapped up neatly together, this creates a “choke.” Are your antennas grounded to the vehicle well?","replyToPid":0}
发表于 2019-5-24 23:39:40 来自手机 | 显示全部楼层
","text":"I was thinking bad ground too, seems like stock antenna truck mounts seem to corrode and go to hell quickly","replyToPid":42943}
 楼主| 发表于 2019-5-26 01:19:46 来自手机 | 显示全部楼层
610123 发表于 2019-05-24 11:01:22 How old is your microphone, sometimes it's as simple as that.
","text":"had it about 2 years now","replyToPid":42936}
 楼主| 发表于 2019-5-27 02:33:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"I got a spare mic. I'll switch to see if it helps","replyToPid":0}
GMT+8, 2026-4-17 22:24 , Processed in 0.110986 second(s), 24 queries .
