查看: 1165|回复: 37
Cruise control
 楼主| 发表于 2019-11-11 23:22:29 来自手机 | 显示全部楼层 |阅读模式
{"text":"I have a 2016 5700 and my cruise control will not maintain the speed I set it at. does anyone else have this problem? is there something I can do to fix this?","videos":"[]","link":"{}","pics":"[]","canComment":true}
 楼主| 发表于 2019-11-12 04:32:28 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I'm not stupid I know there's hills and mountains inclines and declines I'm talking about when I am on Flatland in a straight away and I have it set on 70 and it's doing 68. for your reference I was going to school for aerospace engineering, I'm pretty sure I've taken some Physics classes so I'm pretty sure I'm not stupid when it comes to that topic"}
 楼主| 发表于 2019-11-12 04:56:12 来自手机 | 显示全部楼层
625878 发表于 2019-11-11 20:48:25 I am glad you got the joke. It shows you are a normal human being
","text":"oh I got the joke that's why I made one in return but I also didn't want anyone to think that I was a dumb female either just in case you weren't joking","replyToPid":248377}
发表于 2019-11-15 05:22:33 来自手机 | 显示全部楼层
670777 发表于 2019-11-14 01:15:32 Nope. You’re quite wrong. It reads the airbag pressure?!where do you get this stuff?! I’ve seen your type many times. Living in a make believe world where their equipment is James Bond stuff. Reality.....your truck is like every other one. And it produces a certain amount of power regardless of what your pulling.
","text":"OK, I bow to your divine knowledge. You seem to know way more about about Electronics than I. But I was just simply trying to help the lady get along till she could get to a shop. Weight distribution matters. Besides, driving is my other job. Writing code was my main job.","replyToPid":250710}
发表于 2019-11-14 02:11:58 来自手机 | 显示全部楼层
96080 发表于 2019-11-13 11:22:13 I can only explain it better by saying, it's a 18 wheeled COMPUTER. Put it on a 3 tier CAT SCALE. No more than 12,000 on steers. No more than 34,000 on Drives or Trailer. If set-up properly, the COMPUTER will learn that your within tolerance of weight distribution. Then it will start running properly.
","text":"I have a newer 4900 EX. If I were grossed out at 80k but had 12k, 30k, and 38k on trailer, how could the truck possibly know where the weight is? You make no sense. ","replyToPid":250101}
发表于 2019-11-12 05:20:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"What kind of transmission do you have? If it’s an automatic your boss may have set the profile to Economy mode, which will sometimes shift into neutral and wait until you’re 2 mph under your set cruising speed then shift back into gear in an attempt to save fuel. If that’s the case you can just tap the gear stalk or the accelerator pedal and it will force it back into gear manually. ","replyToPid":0}
发表于 2019-11-12 05:11:46 来自手机 | 显示全部楼层
 楼主| 发表于 2019-11-12 04:29:52 来自手机 | 显示全部楼层
625878 发表于 2019-11-11 20:21:03 It’s called a hill and you are heavier than the car.. so you will down. Physics work and so does gravity
","text":"you don't say I thought the entire Earth was flat","replyToPid":248350}
发表于 2019-11-12 04:41:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"k,  ... well, there are different settings for maximum speed at Cruise and with Petal. But, best thing You can do is displace your weight properly @ 5th wheel and/or trailer slider holes. This way, the computer will allow truck to run without  protecting itself from over- speed or over torqueing.","replyToPid":0}
 楼主| 发表于 2019-11-12 01:01:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"I love this one it has a 82 inch sleeper cherry wood cabinets leather seats it's nice double bunk","replyToPid":0}
发表于 2019-11-13 19:22:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"I can only explain it better by saying, it's a 18 wheeled COMPUTER. Put it on a 3 tier CAT SCALE. No more than 12,000 on steers. No more than 34,000 on Drives or Trailer. If set-up properly, the COMPUTER will learn that your within tolerance of weight distribution. Then it will start running properly.","replyToPid":248630}
 楼主| 发表于 2019-11-11 23:23:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"I should also state that sometimes it does maintain the speed but not all the time","replyToPid":0}
发表于 2019-11-12 00:28:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"Don’t know the fix,but had to say I love them Western Star’s.","replyToPid":0}
发表于 2019-11-12 03:27:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"Um, go to a shop?","replyToPid":0}
 楼主| 发表于 2019-11-12 04:34:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"it worked fine until my boss put a governor on it I just haven't been able to get back by the shop since they've done it","replyToPid":248302}
 楼主| 发表于 2019-11-12 04:53:40 来自手机 | 显示全部楼层
96080 发表于 2019-11-11 20:41:48 k,  ... well, there are different settings for maximum speed at Cruise and with Petal. But, best thing You can do is displace your weight properly @ 5th wheel and/or trailer slider holes. This way, the computer will allow truck to run without  protecting itself from over- speed or over torqueing.
","text":"thanks I'll try that and see if it helps but I should be able to get to the shop and the next two weeks I have them double-check it also","replyToPid":248373}
GMT+8, 2026-3-21 04:35 , Processed in 0.121753 second(s), 24 queries .
