查看: 249|回复: 6
Should I still be on "on duty?"
 楼主| 发表于 2019-11-11 21:36:16 来自手机 | 显示全部楼层 |阅读模式
{"text":"I'm in a breakdown situation on the shoulder of the interstate. Should I still be on \"on duty?\"  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-11-12 00:09:33 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Make sure you have your triangles out, so you don't get a situation for not. Going off duty is good after that"}
回复 支持 3 反对 3
发表于 2019-11-12 07:14:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"technically you should be on duty as your not relieved of all duties while your still waiting for a service truck, but we all go off duty to save that 70hr clock...","replyToPid":0}
发表于 2019-11-11 23:26:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"Off duty ","replyToPid":0}
发表于 2019-11-12 02:08:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"Deploy triangles,off duty ","replyToPid":0}
发表于 2019-11-12 06:37:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yeah stay on duty you are in a repair status and that means you are on duty waiting for the tow truck once the tow truck has the truck go off duty. \n\nMake sure you put your triangles out also. \n\nOne near the drivers door \nOne near the trailer blinker light \nAnd the other one up front close to the front plate. \n\nAnd you should be ok. ","replyToPid":0}
发表于 2019-11-12 13:31:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"triangles, four ways, off duty, and sit in your passenger seat or sleeper. don't give cops a reason to play games.","replyToPid":0}
GMT+8, 2026-4-17 19:44 , Processed in 0.088660 second(s), 24 queries .
