查看: 88|回复: 10
Trying to quit smoking
 楼主| 发表于 2019-11-11 05:06:53 来自手机 | 显示全部楼层 |阅读模式
{"text":"What's a more effective way? Nicotine Patches or Vaping?  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
 楼主| 发表于 2019-11-11 19:05:20 来自手机 | 显示全部楼层
710032 发表于 2019-11-11 04:25:11 Determination, that’s it, just quit, not even one more, my last one was 11/12, never again, best thing I’ve ever done, good luck
","text":"Will keep the mental foritude to do this","replyToPid":247610}
发表于 2019-11-11 12:25:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"Determination, that’s it, just quit, not even one more, my last one was 11/12, never again, best thing I’ve ever done, good luck ","replyToPid":0}
发表于 2019-11-11 19:41:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"Tooth picks and gum","replyToPid":0}
发表于 2019-11-11 20:28:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"I smoked for 38 years. Tried many times to quit. 3 years ago, I made up my mind that I'm not going to buy any \"today\". Haven't had one since. I didn't fight the \"I quit smoking mindset\".","replyToPid":0}
发表于 2019-11-11 19:41:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"Cold turkey!","replyToPid":0}
发表于 2019-11-11 13:13:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"Neither. If you want to quit you must stop using nicotine. It takes 7days to rid your system the rest is kicking the habit. good luck.","replyToPid":0}
发表于 2019-11-11 21:46:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"nicotine lozenges,","replyToPid":0}
 楼主| 发表于 2019-11-11 19:05:34 来自手机 | 显示全部楼层
460010 发表于 2019-11-11 05:13:29 Neither. If you want to quit you must stop using nicotine. It takes 7days to rid your system the rest is kicking the habit. good luck.
","text":"Ill try my best","replyToPid":247635}
发表于 2019-11-12 06:34:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"having a good reason. that's the only thing that worked for me.","replyToPid":0}
GMT+8, 2026-2-13 11:19 , Processed in 0.100563 second(s), 24 queries .
