查看: 51|回复: 4
Which of your qualities do you value most?
 楼主| 发表于 2019-11-10 14:53:49 来自手机 | 显示全部楼层 |阅读模式
{"text":"I strongly believe in doing no harm but taking no chit.","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-11-10 21:57:19 来自手机 | 显示全部楼层
497499 发表于 2019-11-10 10:20:18 When you say “qualities,” I’m assuming you’re referring to beliefs or ideals considering the context of your example, so, basically here’s mine: I don’t believe in a lot of things, but my most deeply felt and rooted and most important value that I hold dearly is the ideal of fairness. Second is respect; for oneself and others, but most importantly for others less able than yourself whom need and deserve your protection and help. Third is honesty. Anything else is ancillary.
","text":"Jesus shortened this in the second part...\"Love your neighbor as yourself.\"","replyToPid":246726}
发表于 2019-11-11 03:40:53 来自手机 | 显示全部楼层
572730 发表于 2019-11-10 13:57:19 Jesus shortened this in the second part...\"Love your neighbor as yourself.\"
","text":"That sums it up nicely. ","replyToPid":246780}
发表于 2019-11-10 18:20:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"When you say “qualities,” I’m assuming you’re referring to beliefs or ideals considering the context of your example, so, basically here’s mine: I don’t believe in a lot of things, but my most deeply felt and rooted and most important value that I hold dearly is the ideal of fairness. Second is respect; for oneself and others, but most importantly for others less able than yourself whom need and deserve your protection and help. Third is honesty. Anything else is ancillary. ","replyToPid":0}
发表于 2019-11-11 03:50:23 来自手机 | 显示全部楼层
GMT+8, 2026-2-15 21:02 , Processed in 0.053743 second(s), 24 queries .
