查看: 94|回复: 5
Tarps
 楼主| 发表于 2019-11-10 05:21:35 来自手机 | 显示全部楼层 |阅读模式
{"text":"Do you fold or roll them? Which is better?  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-11-11 01:17:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"You fold and then roll. The point is to make it easier to lay it out over your load as quickly and safely as possible. Then get yourself back on the ground and bungee.","replyToPid":0}
发表于 2019-11-10 05:57:56 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I roll them just easier for me to open them up when they are frozen. The small light steel tarps don’t matter so much all depends on my mood weather I fold or roll. "}
发表于 2019-11-11 09:02:37 来自手机 | 显示全部楼层
407267 发表于 2019-11-10 17:17:46 You fold and then roll. The point is to make it easier to lay it out over your load as quickly and safely as possible. Then get yourself back on the ground and bungee.
","text":"Always thought the few folds were part of the rolling the tarps not a separate process. ","replyToPid":246940}
发表于 2019-11-11 09:09:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"Right...just trying to clarify not correcting you Meatball. It seemed like a question from someone that has not ever been trained to handle trapping...that's all.","replyToPid":0}
发表于 2019-11-12 10:45:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"7 folds and a roll is all it takes with 2 Bungies","replyToPid":0}
GMT+8, 2026-4-17 16:39 , Processed in 1.667241 second(s), 24 queries .
