查看: 263|回复: 15
How often do you your laundry in a month?
 楼主| 发表于 2019-11-10 04:29:17 来自手机 | 显示全部楼层 |阅读模式
{"text":"Just want to know how much clothes to bring on the road if you are going for a month  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-11-10 13:56:00 来自手机 | 显示全部楼层
发表于 2019-11-10 14:16:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"take 2 weeks worth do laundry 2 x a month","replyToPid":0}
发表于 2019-11-10 15:23:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"Brought way too much clothes with me. Ended up throwing out a good 1/4 of it. Still have way too much though. I only rotate a set of the same sh*t. I recommend bringing around 7 showers worth, a reflective rain coat, winter coat, and maybe summer clothes. If anything, stash away some of the more extreme weather pieces under your bed. If you're doing flatbed though, you may need more.","replyToPid":0}
发表于 2019-11-10 16:16:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"Do you have any laundromats along your route? I usually stock up but if there's a stop with a laundromat and nothing goofy happens I just bring a couple of changes.","replyToPid":0}
发表于 2019-11-10 16:38:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"What happens if you just don't","replyToPid":0}
发表于 2019-11-10 20:31:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"I do laundry once a week or 2 weeks when time permits or at a terminal where it's free. i change underwear and socks everyday and where the same pants for 2 or 3 days and shirt maybe 2 days. Baby wipes are a necessity when you plan to shower and dont get to for whatever reason. Baby wipes on the privates everyday. Stay Fresh My Friends!!","replyToPid":0}
发表于 2019-11-10 22:04:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"once.  I carry a lot of clothing!","replyToPid":0}
 楼主| 发表于 2019-11-11 02:40:50 来自手机 | 显示全部楼层
649124 发表于 2019-11-10 05:56:00 guy...you're going on the road,or team?Well,you should bring at least 4 changes of everything...even though your not changing every day...should change every 3 to 4 days the most...but do bring more underwear and socks...if need be,change every 2 days...
","text":"Thanks for the tip","replyToPid":246581}
 楼主| 发表于 2019-11-11 02:41:02 来自手机 | 显示全部楼层
613522 发表于 2019-11-10 06:16:04 take 2 weeks worth do laundry 2 x a month
","text":"Will keep that in mind","replyToPid":246596}
GMT+8, 2026-4-19 08:17 , Processed in 0.093176 second(s), 23 queries .
