查看: 426|回复: 26
The End of truck driver
 楼主| 发表于 2019-5-24 07:06:48 来自手机 | 显示全部楼层 |阅读模式
{"text":"So who is ready for the big trucks,that drive by themselves 😞","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-5-24 07:56:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"Nobody. Won't happen.","replyToPid":0}
回复 支持 6 反对 0
发表于 2019-5-24 14:08:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"Ok. I’ve commented on this elsewhere.\n\nIt WILL happen.  Autonomous vehicles have already demonstrated they are safer than manually driven.  \n\nThey WILL (for a generation or two) require onboard oversight- at least in the US.\n\nFinding empty trailer is easy- just configure every trailer with a short range transponder, and the truck with a transceiver.  Easy least.\n\n\nWash/washout can be done same way\n\nTarring and loading ","replyToPid":0}
发表于 2019-5-25 06:46:06 来自手机 | 显示全部楼层
Ok. I’ve commented on this elsewhere. It WILL happen. Autonomous vehicles have already demonstrated they are safer than manually driven. They WILL (for a generation or two) require onboard oversight- at least in the US. Finding empty trailer is easy- just configure every trailer with a short range transponder, and the truck with a transceiver. Easy least. Wash/washout can be done same way Tarring and loading
{"replyToPid":42876,"replyTo":"
157862 发表于 2019-05-24 06:08:35 Ok. I’ve commented on this elsewhere.\n\nIt WILL happen.  Autonomous vehicles have already demonstrated they are safer than manually driven.  \n\nThey WILL (for a generation or two) require onboard oversight- at least in the US.\n\nFinding empty trailer is easy- just configure every trailer with a short range transponder, and the truck with a transceiver.  Easy least.\n\n\nWash/washout can be done same way\n\nTarring and loading
","text":"Drive on ice then in AK."}
发表于 2019-5-24 09:29:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"Fukk kinda topic is dis?","replyToPid":0}
发表于 2019-6-9 21:04:21 来自手机 | 显示全部楼层
360638 发表于 2019-06-06 11:26:04 The actual number of years to come to fruition (aside from a few choice safe areas like the desert) they’re looking at a minimum of 50 years.  Each and every one of the automated trucks have been systematically taken off the road for “more research” due to “catastrophic events” involving dead humans \nHmmmmm.  Who could have forseen that? LOL
","text":"Never heard of one autonomous truck killing a human.  A couple cars, yes- and they’re still on the road.\n\nAnd a little research shows autonomous trucks are running right now in the US.   Yes, in limited venues, but they’re running.  It won’t take all that long for them to spread ","replyToPid":56871}
发表于 2019-6-1 10:00:32 来自手机 | 显示全部楼层
659854 发表于 2019-05-29 06:19:35 if we had an EMP what would happen? 🤔
","text":"We could reconfigure most trucks in 4 or 5 hours each to operate without a computer ","replyToPid":47864}
发表于 2019-5-25 10:40:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have.   Look, there will always be exceptions.  You can pick and spit all day, but the fact remains, this stuff is coming. The only question is: how soon","replyToPid":0}
发表于 2019-5-25 02:34:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"we need a dedicated highway for commerce first","replyToPid":0}
发表于 2019-5-24 21:16:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"Ok. I’ve commented on this elsewhere.\n\nIt WILL happen.  Autonomous vehicles have already demonstrated they are safer than manually driven.  \n\nThey WILL (for a generation or two) require onboard oversight- at least in the US.\n\nFinding empty trailer is easy- just configure every trailer with a short range transponder, and the truck with a transceiver.  Easy least.\n\n\nWash/washout can be done same way\n\n)edit- got called away from phone(\n\nTarping and loading ...  \n\nLoading/unloading for most loads can be automated.  Anheuser-Busch already automates their loading in at least one plant. There’s no reason any shipper can’t do the same.  Offloading is just as easy.\n( some loads will be harder to automate, I think, but even nursery and swinging meat loads can be handled by machine)\n\nTarping.  Most of the tarped loads I see could be automated.  Drive into a tarp bay, machine stretches fabric, attaches it to trailer, and you drive out.  You could modify an automatic trailer wash (ok, completely replace the machinery, but you get the idea).  It could even be made “portable”.\nOf course, there will be exceptions, but the tarping/untarping duties can easily be shifted to the relevant customers.\nHeck, it just hit me that a connestoga is just a modified tarping system.","replyToPid":0}
发表于 2019-5-24 20:59:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"Absolutely.  Check it out.  For the number of miles driven, the autonomous vehicles already have a significantly better safety record.  And with every glitch/wreck, the software improves for the entire fleet- something that *cannot* happen with manually driven vehicles","replyToPid":42877}
发表于 2019-5-24 07:58:51 来自手机 | 显示全部楼层
发表于 2019-5-24 08:54:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"Assuming they can drive themselves, what’s to be ready for? Question better put might be, automated trucks- who wants to work for Walmart? ","replyToPid":0}
发表于 2019-5-24 10:46:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"My question in all of this is \"if\" these trucks come to pass, how will these self driving trucks do all the non driving things that we do?\n\nfor example how is a self driving truck going to tarp its load? clean its trailer? unload cars at the dealership? find its empty trailer in the lot? unload its load of fuel at the service station? etc etc \n\nthe people working on this stuff think that driving is all that a truck driver does.","replyToPid":0}
发表于 2019-5-24 14:56:11 来自手机 | 显示全部楼层
","text":"Safer? No.","replyToPid":42876}
GMT+8, 2026-4-18 04:28 , Processed in 0.118867 second(s), 24 queries .
