查看: 250|回复: 8
How much weight do you think can you haul without a CDL?
 楼主| 发表于 2019-11-9 03:19:01 来自手机 | 显示全部楼层 |阅读模式
发表于 2019-11-9 05:08:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"26000","replyToPid":0}
发表于 2019-11-9 03:37:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"Dot don’t seem to care what you do as long as you’re not doing it commercially put a car with a single 2in strap holding it on a trailer non commercial who cares a Cdl driver not having proper spacing between first 2 straps $500 fine and csa points and possibly a level 2 inspection just because F us i guess ","replyToPid":0}
发表于 2019-11-9 03:42:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"https://drivinglaws.aaa.com/tag/types-of-drivers-licenses/    \n\nBut to answer your question just stay below the weight of the Cdl tier stuff depending on states it’s different link above shows each state and levels a license allows ","replyToPid":0}
发表于 2019-11-9 04:06:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"Was going to say that but wasn’t sure if it was universal for all states. ","replyToPid":245414}
发表于 2019-11-9 07:21:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"Just curious what’s your empty weight for the 350 and 24’ trailer? ","replyToPid":0}
发表于 2019-11-9 07:21:40 来自手机 | 显示全部楼层
848274 发表于 2019-11-08 20:27:31 well that's my limit. F350 and 24' gooseneck. no dually with tandem axles single wheel.  I have been known to go 15K for a short distance
","text":"Just curious what’s your empty weight for the 350 and 24’ trailer? ","replyToPid":245438}
发表于 2019-11-10 04:51:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"for Colorado. it's 26,000 gross. 26k - truck = weight you can haul. each state has its own limit. but you can haul otr according to your states license rules","replyToPid":0}
发表于 2019-11-26 23:28:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"what the hell does this even mean?","replyToPid":0}
GMT+8, 2026-4-17 13:14 , Processed in 0.076275 second(s), 24 queries .
