查看: 183|回复: 5
road site checks
 楼主| 发表于 2019-5-24 05:59:25 来自手机 | 显示全部楼层 |阅读模式
{"text":"just started use app. wondering when there's a road side dot check if it will show up on the map?\n ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-5-24 06:02:14 来自手机 | 显示全部楼层
发表于 2019-5-24 07:19:46 来自手机 | 显示全部楼层
586943 发表于 2019-05-23 22:16:03 It is user fed, so if a driver inputs it, then yes... if not, no
","text":"Correct","replyToPid":42580}
发表于 2019-5-24 06:08:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"Hope they see this","replyToPid":0}
发表于 2019-5-24 07:21:56 来自手机 | 显示全部楼层
发表于 2019-5-24 20:45:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"The question is, do the developers read the forums?   My guess, based on my programming days, is “no”.   They’re too busy bug hunting and working other features.  They’ll spot-check, maybe, to see if it’s working, but won’t actually read.\n\n","replyToPid":0}
GMT+8, 2026-4-18 00:52 , Processed in 0.099209 second(s), 24 queries .
