查看: 129|回复: 13
Anyone here own an RV?
 楼主| 发表于 2019-11-8 17:28:48 来自手机 | 显示全部楼层 |阅读模式
{"text":"I'm considering a purchase. I have a few questions from truckers that own a RV. ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-11-9 20:35:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"the 89 was the biggest longest but if you're used to the 8ft sq of you're rig, you'll find anything 22 ft or bigger huge","replyToPid":0}
发表于 2019-11-8 23:06:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"you can live indefinitely most rv parks but the large parks like KOA usually limit your stay so theres no eviction type issues. Check out MCI coaches theres a lot on Ebay. They really liked using the series 60 Detroit engine. Prevost can get expensive especially if they're old touring buses/coaches from music industry.","replyToPid":0}
发表于 2019-11-8 21:00:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"do you have an RV?","replyToPid":0}
发表于 2019-11-8 22:24:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"yes. buy used and buy cash. worse in losing value immediately than a new car. everything leaks from roofs to fixtures. everything shakes after a year like a freightliner. a lot of maintenance and better off doing DIY repairs. What else you got questions on? if you are going new the better quality I've seen at shows are from Lazy Daze and most class 8 chassis, a lot of them go with aluminum siding and roofs because chassis can support it. if you're a rich uncle moneybags go with an earth roamer. if you're going to be pulling a rv trailer upgrade suspension immediately or multiply above issues times 10.","replyToPid":0}
 楼主| 发表于 2019-11-8 22:53:40 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":".."}
 楼主| 发表于 2019-11-8 22:54:11 来自手机 | 显示全部楼层
{"replyToPid":245219,"replyTo":"
682141 发表于 2019-11-08 14:24:39 yes. buy used and buy cash. worse in losing value immediately than a new car. everything leaks from roofs to fixtures. everything shakes after a year like a freightliner. a lot of maintenance and better off doing DIY repairs. What else you got questions on? if you are going new the better quality I've seen at shows are from Lazy Daze and most class 8 chassis, a lot of them go with aluminum siding and roofs because chassis can support it. if you're a rich uncle moneybags go with an earth roamer. if you're going to be pulling a rv trailer upgrade suspension immediately or multiply above issues times 10.
","text":"I'm caught between 5th wheel pull RV and bus model, like the Prevost as an example. I'm looking at used not new and chassis/durability are some of my concerns which you mentioned in your comment. \nHow is the RV community as far as travel and stay? Meaning the areas for RV's to park and/or stay for a month or more? I know this question may be dumb to you/others but I'm not investing in something if its not addressing my needs."}
 楼主| 发表于 2019-11-8 23:01:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"No","replyToPid":245168}
 楼主| 发表于 2019-11-9 00:55:29 来自手机 | 显示全部楼层
682141 发表于 2019-11-08 15:06:51 you can live indefinitely most rv parks but the large parks like KOA usually limit your stay so theres no eviction type issues. Check out MCI coaches theres a lot on Ebay. They really liked using the series 60 Detroit engine. Prevost can get expensive especially if they're old touring buses/coaches from music industry.
","text":"10/4 thanks. Looking into it.","replyToPid":245239}
发表于 2019-11-9 04:17:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"if had a 79 dodge diplomat 26 ft 440 74 dodge swinger 24 ft 440 89 travelcraft 454 34 ft.","replyToPid":0}
 楼主| 发表于 2019-11-9 11:21:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"Accommodating 5-7 or 8-10?","replyToPid":245454}
GMT+8, 2026-2-14 06:08 , Processed in 0.091314 second(s), 24 queries .
