查看: 86|回复: 2
Bill of lading says +24, continuous run, or not?
 楼主| 发表于 2019-1-24 19:23:48 来自手机 | 显示全部楼层 |阅读模式
{"text":"This is fresh poultry. Can I run it on cycle or does it need to be continuous? Hope this isn’t a redundant thread; I checked the forum for answers but most were vague.\n\nThanks","pics":"[]","canComment":true}
发表于 2019-3-8 12:38:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"do whatever the bill tells you to do, if you cycle it and the tell temp somewhere on your freight notices, you're screwed.","replyToPid":0}
发表于 2019-3-11 12:19:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"Anything fresh is always on continuous.","replyToPid":0}
GMT+8, 2026-2-4 09:39 , Processed in 0.063305 second(s), 23 queries .
