查看: 214|回复: 4
I stopped to load diesel and when I started this appeared park brake air low brakes may drag, any solution that you know
 楼主| 发表于 2019-11-8 04:40:04 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[{\"url\":\"http://d2w8udw005hdju.cloudfront.net/video/100516/android_702950_1573159170373.mp4\"}]","link":"{}","pics":"[{\"description\":\"\",\"height\":607.0,\"name\":\"\",\"url\":\"\",\"width\":1080.0}]","canComment":true}
 楼主| 发表于 2019-11-8 07:41:25 来自手机 | 显示全部楼层
742208 发表于 2019-11-07 22:00:45 Check your brake chamber truck and trailer
","text":"yes , that was the problem... thanks","replyToPid":244735}
发表于 2019-11-8 04:49:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"check your glad hands. are they tight. maybe a hole in the red line.","replyToPid":0}
发表于 2019-11-8 06:00:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"Check your brake chamber truck and trailer ","replyToPid":0}
 楼主| 发表于 2019-11-8 07:41:44 来自手机 | 显示全部楼层
38425 发表于 2019-11-07 20:49:07 check your glad hands. are they tight. maybe a hole in the red line.
","text":"it was the chamber brake","replyToPid":244704}
GMT+8, 2026-4-19 08:16 , Processed in 0.084013 second(s), 24 queries .
