查看: 250|回复: 13
Window Slush
 楼主| 发表于 2019-11-7 09:17:52 来自手机 | 显示全部楼层 |阅读模式
{"text":"Any ideas how to keep ice n snow from building up on Cascadia windows? Thinking about putting heat tape around the window and plug it into my inverter 🤣","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":980.0,\"name\":\"\",\"url\":\"\",\"width\":2016.0}]","canComment":true}
发表于 2019-11-7 12:25:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"Point the truck south and don’t stop until temps warm up.","replyToPid":0}
回复 支持 8 反对 0
发表于 2019-11-7 12:21:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"turn your defroster on and lower your sun visor to stop air   from scaping","replyToPid":0}
发表于 2019-11-7 09:32:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"12v heater. Place on the bottom of your windshield. \n\nDump a bottle of isopropyl alcohol in with your washer fluid and hit it. ","replyToPid":0}
发表于 2019-11-7 11:31:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"put some air line antifreeze  or isopropyl alcohol in with the washer fluid","replyToPid":0}
发表于 2019-11-7 16:56:05 来自手机 | 显示全部楼层
310244 发表于 2019-11-07 04:25:17 Point the truck south and don’t stop until temps warm up.
","text":"This is the big brain answer","replyToPid":244166}
发表于 2019-11-7 11:14:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"Rain x spray works well with defrosting ","replyToPid":0}
发表于 2019-11-7 09:34:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"Change air filter I had cascadia it’s hard to keep whole window clean defrost on high","replyToPid":0}
发表于 2019-11-7 09:27:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"Defrost ","replyToPid":0}
 楼主| 发表于 2019-11-7 09:29:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"On high dont work great. looking to improvise.","replyToPid":244028}
GMT+8, 2026-2-13 02:22 , Processed in 0.127275 second(s), 24 queries .
