查看: 361|回复: 22
How did you overcome that nervous feeling when you are backing up?
 楼主| 发表于 2019-11-7 04:26:06 来自手机 | 显示全部楼层 |阅读模式
{"text":"Am I the only one can't seem to overcome this. Or is it really like this all through out your trucking career  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-11-7 07:26:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"Ask an experienced mentor for some rules of thumb. It really depends on the room allotted and your tractor/trailer lengths, but with a 53ft van/reefer in a modern conventional if you stick to the left, pass the first two spaces in your tractor, then turn the wheel all the way to the right and proceed in 1st gear slowly until you’re facing the opposite direction of the spaces behind you, then turn the wheel all the way to the left and proceed until your tractor is at a perfect right angle from the row you want to back into, then stop, open window, poke head out and see if you may need to pull forward some more or if can swing perfectly in the space you want. Look at the corner of your trailer and your tandems and imagine a line from them into the space you want. And just kinda do the reverse of that, adjusting slowly as you back up. And pull up and adjust as you need to. It’s easier than it feels. Just keep practicing and YouTube or Google some tips. ","replyToPid":0}
发表于 2019-11-7 06:04:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"Practice backing between dropped trailers every chance you get so you don't have to worry about smashing someone's truck. Eventually it'll be second nature no matter what you're backing into. It took me a solid 6 months of backing in tight train yards a few times a day to get confident at it. But those trailers are steel and the paint barely scratches if you hit them. Ask me how I know, lol.","replyToPid":0}
发表于 2019-11-7 04:59:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"Repetition ","replyToPid":0}
发表于 2019-11-7 06:49:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"the best and most important.  don't rush, any chance of questioning.  get the hell out and go look.. common sense!!!","replyToPid":0}
发表于 2019-11-7 06:16:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"Take a deep breath, get out and look around, and hopefully you got good training. That way you can trust your training. The number one is practice practice as time goes by you will be a old pro at it.","replyToPid":0}
 楼主| 发表于 2019-11-10 02:25:02 来自手机 | 显示全部楼层
497499 发表于 2019-11-06 23:26:44 Ask an experienced mentor for some rules of thumb. It really depends on the room allotted and your tractor/trailer lengths, but with a 53ft van/reefer in a modern conventional if you stick to the left, pass the first two spaces in your tractor, then turn the wheel all the way to the right and proceed in 1st gear slowly until you’re facing the opposite direction of the spaces behind you, then turn the wheel all the way to the left and proceed until your tractor is at a perfect right angle from the row you want to back into, then stop, open window, poke head out and see if you may need to pull forward some more or if can swing perfectly in the space you want. Look at the corner of your trailer and your tandems and imagine a line from them into the space you want. And just kinda do the reverse of that, adjusting slowly as you back up. And pull up and adjust as you need to. It’s easier than it feels. Just keep practicing and YouTube or Google some tips.
","text":"THanks. ALways doing the google and youtube. Still I don't want to mess up. Maybe that's why I am really nervous.","replyToPid":243971}
发表于 2019-11-7 06:52:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"First thing I do when I’m backing in somewhere, roll my window down. It gets rid of any glare that could interfere with your vision. It also allows you to hear if somebody yells that you’re going to hit something or run over something or someone. It also allows you to stick your head out the window to see where your trailer is exactly tracking. Backing was the first thing I ever learned in a truck, but I realize that not everyone has the opportunity to learn it first, like I did. But, as Straight Team said above, practice in drop lots and empty lots as much as possible until you get that confidence.","replyToPid":0}
发表于 2019-11-10 04:14:39 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I think taking your sweet time and not overthinking it is key. Anxiety’s a difficult thing to overcome. Just know we’re all in this thing together and don’t feel like you’re in someone else’s way and try and stay logical about it. "}
发表于 2019-11-7 07:22:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"When I quit hearing glass break!","replyToPid":0}
 楼主| 发表于 2019-11-10 02:24:08 来自手机 | 显示全部楼层
558104 发表于 2019-11-06 23:13:54 Just remember the first person you run over is the most difficult to get over. It gets a lot easier after that.
","text":"Wait.WTH?","replyToPid":243967}
发表于 2019-11-7 16:58:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"Honestly just took time, homie","replyToPid":0}
发表于 2019-11-7 17:24:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"Not nervous. More cautious.","replyToPid":0}
GMT+8, 2026-4-17 16:37 , Processed in 0.179457 second(s), 24 queries .
