查看: 229|回复: 5
Saw this question on another forum. What would you advice this guy?
 楼主| 发表于 2019-11-7 04:02:20 来自手机 | 显示全部楼层 |阅读模式
{"text":"Here's his question:\n\n\"So I work for a company, and they love to use personal conveyance to go pick up loads when your out of time. Is there any way to combat that and not get fired?\"  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-11-7 04:20:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"honestly if they'd fire you for not breaking the law then they're not worth it.","replyToPid":0}
发表于 2019-11-7 07:30:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"There’s a DOT whistleblower hotline you can call. Google it. ","replyToPid":0}
发表于 2019-11-7 05:13:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"pickup the cell phone and report them to the Feds.  get them on a voice recorder first but dont let them know.\nalso can report it to your safety department.","replyToPid":0}
发表于 2019-11-7 06:38:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"Should probably leave before they DO get reported and shut down. God forbid one of the drivers get into a predicament and the logs get audited.  Run while you can.","replyToPid":0}
发表于 2019-11-8 09:20:55 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"(888)-368-7238 dot hotline to report the company anonymously. You have to give them your info but they will keep your name off the record when they open the investigation into the company "}
GMT+8, 2026-4-17 16:37 , Processed in 0.086353 second(s), 25 queries .
