查看: 117|回复: 6
Trucker Path GPS
 楼主| 发表于 2019-11-4 22:17:39 来自手机 | 显示全部楼层 |阅读模式
{"text":"Does the GPS on this app works well for trucks I mean avoiding no truck route, bridges and stuff like that ? Have u guys had any bad experiences?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-11-5 07:37:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"Not if you do your homework first with GOOGLE MAPS or Truvker's Path to check your route. I've been out here since 1976 and thank God have never gone down a wrong road.","replyToPid":0}
发表于 2019-11-5 01:27:28 来自手机 | 显示全部楼层
658864 发表于 2019-11-04 16:18:43 I don’t pay for the Trucker path GPS, but on Friday I did use the map that shows the truck stops . Since they added the low clearance feature it was helpful, I simply zoomed in the area I was in and found a good route. It made me a little bit nervous because we ( a brunch of trucks rerouted to avoid a congested area ) got to a bridge that the clearance said 13’5” and it wasn’t on the trucker path map, but we   fit!
","text":"most bridges Market 13-5 have between 3 and 6 in of extra clearance to make way for snowpack glad you made it safely Keep On Truckin keep the shiny side up","replyToPid":242077}
发表于 2019-11-5 03:33:39 来自手机 | 显示全部楼层
770536 发表于 2019-11-04 17:27:28 most bridges Market 13-5 have between 3 and 6 in of extra clearance to make way for snowpack glad you made it safely Keep On Truckin keep the shiny side up
","text":"Truth of the matter  I waited on the shoulder till another braver trucker passed , but ,yes, it seemed there was plenty of room to go under that bridge","replyToPid":242164}
发表于 2019-11-5 01:26:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"no GPS is foolproof all of them will eventually at some point take you down either a dead end Road or turn you on a path that you should not be on this one works decently well so does the road Hunter app which is free so does the CDL life app which is personally from experience a lot better but I still use my Google Maps to find out where the police have set up in such as well as the CoPilot app for Android which has it setting for trucks and avoiding tolls and it's also free","replyToPid":0}
发表于 2019-11-5 00:18:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"I don’t pay for the Trucker path GPS, but on Friday I did use the map that shows the truck stops . Since they added the low clearance feature it was helpful, I simply zoomed in the area I was in and found a good route. It made me a little bit nervous because we ( a brunch of trucks rerouted to avoid a congested area ) got to a bridge that the clearance said 13’5” and it wasn’t on the trucker path map, but we   fit!","replyToPid":0}
 楼主| 发表于 2019-11-5 00:44:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"oh shit yeah i think rerouting is where I have only really mess up or were I have almost got stuck but you know I was owner back then and If I had to lift the truck up my self so I didnt have to call the tow truck I would have tried 🤣","replyToPid":0}
GMT+8, 2026-2-12 00:26 , Processed in 0.097605 second(s), 24 queries .
