查看: 234|回复: 6
Fyi .. Pilot Hwy 395 Hesperia, CA
 楼主| 发表于 2019-11-4 21:41:19 来自手机 | 显示全部楼层 |阅读模式
{"text":"If your coming through this area and need to take a break beware. You will see trucks parked on the street surrounding this location. Don't do it. You'll start your equipment check with a pink ticket stuck on your windshield or mirror arm. If no parking is available in the lot. There's dirt lots across from the Pilot one facing west and the other south. It's ok to park there. ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-11-5 00:19:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"also behind the pilot will work, near the washes","replyToPid":0}
发表于 2019-11-4 22:57:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"thanks for the heads up 👌","replyToPid":0}
 楼主| 发表于 2019-11-5 01:35:39 来自手机 | 显示全部楼层
634842 发表于 2019-11-04 14:57:33 thanks for the heads up 👌
","text":"10/4","replyToPid":242032}
 楼主| 发表于 2019-11-5 01:35:49 来自手机 | 显示全部楼层
发表于 2019-11-5 06:05:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"Don't forget to grab chow at the Outpost!","replyToPid":0}
 楼主| 发表于 2019-11-6 05:12:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"Have yet to try. I always end up at east of there or Victorville. Might try it next go round.","replyToPid":0}
GMT+8, 2026-2-13 23:10 , Processed in 0.086208 second(s), 24 queries .
