查看: 183|回复: 7
Chains
 楼主| 发表于 2019-11-4 04:47:49 来自手机 | 显示全部楼层 |阅读模式
{"text":"How long does it usually take to set up?  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-11-4 06:58:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"if it's bad enough you need chains, you dont need to be out therr","replyToPid":0}
发表于 2019-11-4 16:55:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"It depends on conditions and how many chains needed. It took me 4hrs once due to not enough traction to even be able to drive onto chains, hands being cold I couldn’t even tighten the chains, chains tangled. But lessons learned that night ","replyToPid":0}
发表于 2019-11-4 20:14:54 来自手机 | 显示全部楼层
{"replyToPid":241948,"replyTo":"
456441 发表于 2019-11-04 08:55:27 It depends on conditions and how many chains needed. It took me 4hrs once due to not enough traction to even be able to drive onto chains, hands being cold I couldn’t even tighten the chains, chains tangled. But lessons learned that night
","text":"So what did you learn?"}
发表于 2019-11-4 21:34:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"For one never to end up in that kind of situation to begin with I failed to check the weather as it usually doesn’t get so bad that time of year. Also Untangle chains prior to having to use them, also do a dry run in the warmer weather as a refresher before you’re on the side of the road freezing your balls off with cars and trucks alike all around you sliding in the chain pullout. Also learned when going down try and ride the rumble strip to keep from loosing traction when it’s really bad ","replyToPid":0}
发表于 2019-11-4 21:34:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"For one never to end up in that kind of situation to begin with I failed to check the weather as it usually doesn’t get so bad that time of year. Also Untangle chains prior to having to use them, also do a dry run in the warmer weather as a refresher before you’re on the side of the road freezing your ba11s off with cars and trucks alike all around you sliding in the chain pullout. Also learned when going down try and ride the rumble strip to keep from loosing traction when it’s really bad ","replyToPid":0}
发表于 2019-11-4 21:35:51 来自手机 | 显示全部楼层
456441 发表于 2019-11-04 13:34:54 For one never to end up in that kind of situation to begin with I failed to check the weather as it usually doesn’t get so bad that time of year. Also Untangle chains prior to having to use them, also do a dry run in the warmer weather as a refresher before you’re on the side of the road freezing your ba11s off with cars and trucks alike all around you sliding in the chain pullout. Also learned when going down try and ride the rumble strip to keep from loosing traction when it’s really bad
","text":"But that was 3 years ago when I was new and dangerous ","replyToPid":242001}
发表于 2019-11-6 10:31:12 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I'll tell you the first time I have to do it.  Have yet to need to use them.  Been plenty of times I've seen other drivers chain up and last year had 2 times where they were required (i84 in Oregon) and I ignored and had no issue.\n\ntwo non-chain tips...\nSnow provides better traction then ice.  It may seem backwards, but the tire tracks have packed snow and ice from constant traffic.  If the roads aren't treated, you can have much better traction by NOT following the tire paths created by traffic.\n\nSteady on throttle and light.  If climbing or descending a hill set your gear lower then needed so you wont have to use as much power and can easily maintain a slower and steady speed up or down the hill."}
GMT+8, 2026-4-17 19:44 , Processed in 0.063207 second(s), 24 queries .
