查看: 142|回复: 9
which truck stop's you preferred???
 楼主| 发表于 2019-11-3 11:18:11 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":500.0,\"name\":\"\",\"url\":\"\",\"width\":707.0}]","canComment":true}
 楼主| 发表于 2019-11-3 11:36:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"lol I agree 💯 with you on that one 😂","replyToPid":0}
回复 支持 2 反对 3
发表于 2019-11-3 11:45:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"petro","replyToPid":0}
 楼主| 发表于 2019-11-3 11:56:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"👍","replyToPid":241108}
发表于 2019-11-3 12:34:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have over two thousand u.s. dollars to spend on anything I want inside of Loves truck stops. Because I only fuel at Loves. But never stay more than thirty minutes. I sleep in small mom and  pop truckstops, rest areas, or worse case scenario on an on ramp","replyToPid":0}
发表于 2019-11-3 12:08:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"most TA and Petro are garbage","replyToPid":241108}
发表于 2019-11-3 20:31:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"I go to mom and pa ones or petro or ta","replyToPid":0}
发表于 2019-11-3 20:03:51 来自手机 | 显示全部楼层
612134 发表于 2019-11-03 04:34:23 I have over two thousand u.s. dollars to spend on anything I want inside of Loves truck stops. Because I only fuel at Loves. But never stay more than thirty minutes. I sleep in small mom and  pop truckstops, rest areas, or worse case scenario on an on ramp
","text":"Yup unless I stop earlier in the day it’s rest areas small truck stops ramps for me too. Or shipper receiver since I usually haul equipment and they don’t care that I’m there. ","replyToPid":241129}
发表于 2019-11-5 10:37:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Rest areas, interstate ramps, or the warehouse only.","replyToPid":0}
发表于 2019-11-6 03:48:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"Whichever one has the best coffee.  Depends on where you are, really.  But I do my best not to park at any of the big 3.","replyToPid":0}
GMT+8, 2026-2-14 14:55 , Processed in 0.077537 second(s), 24 queries .
