查看: 82|回复: 4
Power Inverter recommendations.... Any and all feed back is welcome...
 楼主| 发表于 2019-11-3 09:27:47 来自手机 | 显示全部楼层 |阅读模式
{"text":"What power inverter can someone recommend for a mini fridge, works at 96 watts steady-300 peak when compressor kicks in. would like it big enough if in the future i put a tv not really planning on a microwave.","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-11-3 09:55:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"2000 watts are a good number to go with","replyToPid":0}
发表于 2019-11-3 09:53:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"Cobra CPI 1575, it’s a 1500w, it’s what I had in my first truck and ran everything that I had. I got mine on eBay for around $100 without the wiring kit, I’m not sure on the cost with the kit","replyToPid":0}
发表于 2019-11-3 10:48:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"Cobra 3000 watt's from Amazon or eBay\nI'm running on it!! Haier fridge an coffee maker all at same time, now you keep your fridge plugged in at all times without the truck being running,\nbut coffee maker or other appliance toaster microwave\nthen yes you need to have the truck running in order to maintain high voltage supplying inventor,\nmake sure you get the heavy duty cables","replyToPid":0}
发表于 2019-11-4 11:24:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"Minimum 2000 watts   ","replyToPid":0}
GMT+8, 2026-2-13 21:04 , Processed in 0.109698 second(s), 24 queries .
