查看: 242|回复: 7
Cost of Paint?
 楼主| 发表于 2019-11-2 16:47:53 来自手机 | 显示全部楼层 |阅读模式
{"text":"I scratched a fellow drivers truck backing into a parking spot in a new yard (Parking spots were not wide enough). It's a 2015 cascadia and drivers side front fender. I got a quote for $1200! that sounds really high. thoughts?","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":2016.0,\"name\":\"\",\"url\":\"\",\"width\":1512.0}]","canComment":true}
发表于 2019-11-2 20:40:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"question... if the spots weren't wide enough why did you do it anyway...that seems pretty foolish and you deserve to pay for your mistake","replyToPid":0}
发表于 2019-11-2 21:20:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"it could have been avoided with common sense","replyToPid":0}
发表于 2019-11-2 20:58:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"it could have been alot worse","replyToPid":0}
发表于 2019-11-2 21:20:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"why fix it leave it as a remi der not to do that again!!!","replyToPid":0}
发表于 2019-11-2 21:25:02 来自手机 | 显示全部楼层
106326 发表于 2019-11-02 13:20:30 why fix it leave it as a remi der not to do that again!!!
","text":"it's someone else's truck he scratched","replyToPid":240430}
发表于 2019-11-3 08:05:10 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"With a shop doing it, yes, $1200 makes sense because it looks like there is actual damage, not just paint scuffs.  The shop will either replace the piece completely or repair and paint the entire thing to look brand new.\n\nBut, if you ever get a scratch on your own vehicle that is your own fault, just stop at a walmart and buy some paint from the auto department.  they have small tubes for touching up scratches and dings."}
发表于 2019-11-3 08:58:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"Not bad at all ‼️‼️😂😂😂","replyToPid":0}
GMT+8, 2026-4-18 12:46 , Processed in 0.142577 second(s), 24 queries .
