查看: 220|回复: 14
Electric blanket
 楼主| 发表于 2019-11-1 22:18:14 来自手机 | 显示全部楼层 |阅读模式
{"text":"I am thinking of buying an electric blanket for those times that I cannot idle. Is it effective and does it drain the battery?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-11-2 08:09:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"A 12 hour candle will keep you warm all night and you’ll have to crack a window or you’ll sweat to death","replyToPid":0}
发表于 2019-11-1 23:55:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"Get a sub-zero sleeping bag. ","replyToPid":0}
发表于 2019-11-1 22:58:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have one. don't have any issues with battery drain but I keep it on the lowest setting.","replyToPid":0}
发表于 2019-11-1 22:44:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"They can, unless you’re using an APU. There are battery operated electric blankets as well though. I found one on Amazon for $170. Comes with a rechargeable battery pack. ","replyToPid":0}
发表于 2019-11-1 23:33:57 来自手机 | 显示全部楼层
发表于 2019-11-2 00:07:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"I like those internationals with the sleeper heater and AC in the passenger side box . your overweight with a bottle water load when you have a that other thing","replyToPid":0}
发表于 2019-11-2 00:09:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"flatbed drivers wear 2 sweat suits under their clothes in the winter","replyToPid":0}
发表于 2019-11-2 01:20:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"Let's snuggle to keep warm","replyToPid":0}
发表于 2019-11-2 03:53:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"get a sleeping bag, you are the heat source.","replyToPid":0}
发表于 2019-11-2 04:17:31 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I had one before. Put it under me and cover with a regular blanket . Keeps you  warm down to about 30° but I did get a head cold since I can't stand covering my head. \nAs to battery drain it uses very little power so no problems with  it and cooler running all night"}
GMT+8, 2026-2-14 02:27 , Processed in 0.123406 second(s), 24 queries .
