查看: 46|回复: 2
Absolutely, the trucking industry is here to stay for a long time. Some aspects of the industry may change over time,
 楼主| 发表于 2019-11-1 08:02:23 来自手机 | 显示全部楼层 |阅读模式
{"text":" but trucks will be around long after my lifetime.\n","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-11-1 08:33:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"Unless every Walmart is on a railhead, you need trucks to deliver goods.","replyToPid":0}
发表于 2019-11-1 11:04:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"automated trucks exist now.  the regulatory hurdles will likely be more difficult than the technical ones.\n\nmy unsolicited advice to younger drivers is to always be thinking of what to do next.\n\nthose high tech tricks will need some pretty good technicians to support them.  if I was a youngster again I'd be learning as much as I can about them.","replyToPid":0}
GMT+8, 2026-2-11 10:49 , Processed in 0.067890 second(s), 23 queries .
