查看: 239|回复: 4
When you see it....
 楼主| 发表于 2019-11-1 07:28:12 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":960.0,\"name\":\"\",\"url\":\"\",\"width\":720.0}]","canComment":true}
发表于 2019-11-1 23:18:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Air conditioner is bent. Think that strap was intended to keep the stacking boards on the unit. Those units aren't usually wide.  The largest units I've seen are 8ftx8ftx50ft and are bolted to the trailer.  Hope that strap isn't all the securement used.","replyToPid":0}
发表于 2019-11-2 01:06:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"Lololol","replyToPid":0}
发表于 2019-11-2 01:08:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"The straps are supposed to go ONLY on the ends of the A/C units.Anywhere else and they bend.\n\nThis genius doesn’t have the strap going to the trailer,it’s hooked on to the bottom of the A/C 😂.","replyToPid":0}
发表于 2019-11-2 02:23:29 来自手机 | 显示全部楼层
794377 发表于 2019-11-01 03:25:33 Does not look like it is strapped to the trailer
","text":"Not strapped to the trailer, Lol","replyToPid":239550}
GMT+8, 2026-2-11 15:45 , Processed in 0.066560 second(s), 23 queries .
